Fuse Block Change:Glass fuses to Blade 65Ranchero - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2011, 03:38 PM
Want to update fuse block on 65 Ford Falcon Ranchero from: glass fuses to blade, any help or direction would be most welcome
Old 08-24-2011, 06:45 PM
I don't think there is an easy way to make that conversion. Most vehicles did start using blade fuses until the late 70's, and I don't think there is a late 70's Ford that would have a fuse block similar to the 65 Ranchero. If you are very patient you could probably wire the car up to a generic blade fuse block from Painless wiring.
Bruce
Old 08-24-2011, 07:56 PM
kc0kfg's Avatar
kc0kfg
I have an idea but I have to ask why?
I suppose you could make some adapters using .22 shell casings (used) and silver solder some terminals that would accept the blade type fuses.
You could even scrounge the terminals from a junk yard fuse box.
But I have to ask whats wrong with the glass ones? I know they can be hard to find late on a Sunday night, but if you stock up on them before you need them....
Old 08-24-2011, 08:22 PM
EOD Guy's Avatar
they do make some auto circuit breakers that have round lugs that will fit into the glass fuse box, not cheap tho......
Old 08-25-2011, 11:09 AM
Thank you guys for your response.
I found a generic fuse block at the auto parts store. it has a 4 circuts ,but you can attach an additional 4 circut block, giving you 8 circuts. I think it will be pretty simple to convert.
Oldman1934
Old 08-25-2011, 12:25 PM
35terraplane's Avatar
Fuse Block
Oldman1934
The question I have, why the fuse block, What about the wires, they are 45 years also. I would be more worried about them. If you are changing fuse block because fuses are blowing, believe me it's not the fuse block.
You could put a board in there and wires, for around $200. The fuse board has the flashers, the ballast resistor, the Horn relay. All blade type fuses, some are self setting or you can replace all of them to self setting, for more money. If you want to change them over you can also buy one or two at a time. The board is made for your car with your engine and steering column. The sheets of instructions that come with it tell you what you are doing. it also has a diagram of each circuit. it tells you what size wire to use.
The board cost $150.00, you don't see them advertised, as he sells enough with out. all the wires go in on one side you can buy your own wire which is about $70.00 worth and he has labels you can put on the wire if you want. or you can do like other board makers do and pay $200. plus just for the wire because it has the circuit name on it.
Pm if you would like the name, Oh a lot of the big name builders use this board in the cars they build. He is out in CA. I have done over 200 cars with his board. very easy to use.
Bob
Old 08-25-2011, 12:34 PM
boatbob2
fuses (post hijack)
Hi,i just replaced ALL the blade type fuses in my various cars,trucks and my motor coach,with fuses with a built-in LED,when the fuse blows.the red LED light comes on.easy to find blown fuse.,i bought mine from DEL city.com
Old 08-26-2011, 11:14 AM
Bob
Thank You Bob;
The Wiring is fine very pliable and no damage. It was my desire to provide an update. and have found the best way. I did purchase a wiring kit, but it far exceeds the needs I have. There are wires serving the tail lights ,which I will be replacing.
Thanks again,
Richard
Old 08-26-2011, 01:25 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
This is a funny fusebox as well.
maybe 6 fuses and 5 different physically sized fuses---weird.
Just the bare minimum in these things.
But---I just have a blast driving mine.
Handed down from my uncle who bought it new.
High performance 289 and 4-spd car-----yeeeee haaaaw
86 chevy pickup glass fuse or ATO??? Overdriv Electrical 2 03-30-2011 06:05 PM
fuse block change cheezehead69 Electrical 3 04-05-2009 08:16 PM
Alternator to Fuse Block ryankalel Electrical 4 11-11-2008 08:02 AM
Fusible link / blade fuse propaneburner Electrical 7 01-31-2008 07:44 AM
Fuse Block Nic1979 Electrical 8 08-09-2005 02:21 AM
