Fuse Box
2K views 2 replies 2 participants last post by  phil1949
ON MY DODGE RAM 100 1986 FUSE BOX ALL FUSES GOOD BUT NO POWER TO HEADLIGHTS. ON THE REAR OF FUSE BOX THERE ARE 3 CONNECTORS THEY LINE UP WITH FUSES ON THE FRONT OF FUSE BOX. AT THE CONNECTORS THERE IS VOLTAGE EXCEPT TO MIDDLE CONNECTORS NO VOLTAGE. THIS NO VOLTAGE CONNECTORS I THINK GIVES VOLTAGES TO THE FUSES THAT RUN THE LIGHTS. TRACED THE WIRE TO THE REAR OF WHAT THE BOOK CALLS BULKHEAD CONNECTOR 50 WAY. I CALL IT A JUNCTION BOX, THERE ARE NO FUSES ARE RELAYS INSIDE JUST,50 CIRCUITS MALE AND FEMALE I THINK THAT CONNECT TO EACH OTHER. MY QUESTION IS ON THIS WIRE CAN I CHECK FOR VOLTAGE IF SO [I DID AND THERE IS NO VOLTAGE THIS IS AT THE REAR OF THE BULKHEAD CONNECTOR UNDER THE DASH] DO I GO UNDER THE HOOD REMOVE ALL THE COVERING ON THE WIRING HARNESS FIND THE WIRE AND CHECK VOLTAGE THERE AND TRACE TO HEADLIGHTS TOWARD BATTERY. THIS THE ONLY THING I CAN THINK OF. HAVE CHECKED EVERYTHING ELSE. SORRY THIS POST IS SO LONG.
