Fuse box - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2004, 12:39 PM
Question Fuse box
I have a '80 Trans Am Turbo SE. I have encountered some problems with fuse location because the writing on the fuse panel is worn away. I was wondering if anyone has a picture or diagram that could help me out.
Thanx
Turbo Terror
Old 12-26-2004, 04:04 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
If you can not find a diagram.Get you a test light and run across the tips.Do this with the key off and the key on.Some fuses are powered with the ignition off.if it is properly grounded the light will tell you which fuse is bad.
Old 12-26-2004, 06:58 PM
poncho62's Avatar
Wiki Edits: 5
There is probably a diagram in an owners manual.
GM fuse panels have battery power on one side and battery power on the other.
