Fuse link AMP rating - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2006, 01:47 PM
I am trying to make sense of the wiring on a 1988 Ford diesel F250 that has been cobbled almost beyond repair. Right now I need to replace a 20 ga fuse link with an inline fuse and I would like to know the AMP rating that would be required for this? Is there a downside to using the fuse instead of the fuse link?
The Following User Says Thank You to oldred For This Useful Post:
jjdjjd (07-25-2016)
Old 07-27-2006, 02:32 PM
302 Z28's Avatar
Here is a good wire amperage online reference. Some like fuse links some don't. A fuse link will take longer to blow and will not blow in an instant like a fuse will if you get an intermittent short.
Vince
Old 07-27-2006, 03:14 PM
Thank you
No prob, your welcome.
Vince
Old 07-27-2006, 05:14 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The Downside to using a Maxi~Fuse IS:
It is too easy to just keep popping them in without corrective action UNTIL you DO have a fire..
(My opinion only..basied on non~Electrical guy's that have done this over the years..)
Like The Circuit breaker in your house that keeps tripping..you just reset it and move on until the next time..But hardly Troubleshoot the circuit OR call a proper Electrician.
A wired Fuse Link works by MELTING the link, which requires WORK to replace , as the wires around it must be re~Crimped or soldered, shrink tubing applied and the like..MOST folks will find and fix the problem BEFORE replacing a link so as not to have to replace it again! as, opposed to just popping in a maxi fuse.
BOTH work fine...Provided you do the right thing when it goes out..a link or maxi fuse will not blow "on a Spike" or "Freak".. Something Devastating has happened to the current delivery source (hot side of the battery, Alternator..) that , If not protected by the link, would have Burned your rod to the ground..
To find out the link size, you need to find out the Ampacity of the gauge wire over a given number of feet in length. If your wire supports 60 amp draw maximum, you need to match that number and slightly higher or lower, whatever the next closest link will be..
A Common misconception is : A Fuse or link protects the end user device..not true , It is designed to protect the wire in between the Source current (battery) and the load (Device)..using that theory, a fuse is useless with most modern electronics...an over draw will destroy a computer or CD device in Milliseconds ...Long before an analog fuse would ever open. by the time it did..the damage would be done and the resulting damage would most likely only add to more draw.
NEVER bypass a Fuse link...or run without one where one was supplied..Next time your tempted, Think of this : Would I bypass My fuse box in my house straight to the meter? and sleep well at night, knowing my family was in the house? YOUR house DRAWS less current than your battery is capable of supporting..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-27-2006, 08:33 PM
Doc, I found and corrected the problem (the guy had clamped a bracket down on the wire going to the fuel shut off solenoid) before I even started to replace the link. This wire is connected, by a fuse link, to the power supply that is hot with the key on only and there is no other fuse in the circuit. This is a 20 ga fuse link that is burned and is what I would replace it with if it was mine however the fellow that owns the truck wants it replaced with an inline fuse and I was wanting to know what would be the proper amp fuse to replace this 20 ga link with.
Old 07-28-2006, 02:28 AM
aka Duke of URL
Red,
To figure the fuse AMP rating you would need to know the draw of the component/circuit. I would replace the fusible link and send him on his merry way because if something else happens on that circuit and the blade fuse doesn't catch it in time, you will be the no good S.O.B. that messed up my truck
You can get the link either at the dealer or most any parts house. I would cover my butt on this one. If he grounded out this circuit by foolishness, who knows what he will do next...
D3AZ 14526-S
9" L 20 GA. Blue Insul (Eyelets)
D3AZ 14526-M
9" L 20 GA. Blue Insul (Stripped Ends)
Old 07-28-2006, 06:18 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
What GAUGE wire is the load side of the link? 20 Gauge also?
If 20 Gauge, Maxi Fuse it for 10 amps...(max is 11. 1 amps..)
If the wire is bigger, look up the ampacity of the wire and fuse it accordingly.
Doc
Innovations
need help with a 12 v to 6 v reducer oldguy829 Electrical 32 08-21-2006 06:02 PM
fuse size for 8 gauge- main feed powderbill Electrical 12 04-21-2006 08:08 PM
ac to dc amp rating HELP???? Ratchet Electrical 7 01-23-2006 05:53 PM
75 amp Battery fuse Mr.NutCase Electrical 1 12-28-2005 07:49 PM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 12:03 PM
