Fuse Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2005, 01:11 AM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
Fuse Problems
I got a 65 Chevy Impala.I keep having a problem with the fuse blowing out.Its the fuse for the Dash lights and the brake lights.The same fuse runs both.Is that right or is something wired wrong?The fuse keeps burning out everytime I have the dash lights(Headlights) on and I hit the brakes it will burn it out.Any ideas what is causing this?Any help is appreciated.Thanks,
Eazy
Old 07-20-2005, 01:54 AM
77z's Avatar
77z 77z is offline
Go big or go home
Could be as simple ans a bad 1157 stop turn tail lamp in the rear i would prolly check all of those first
Regards Mike
77 Z28 496 9 inch
10.23 @ 129
Old 07-20-2005, 04:42 AM
302 Z28's Avatar
I agree, I would pull all the bulbs associated with this circuit and re-install them one at a time to insure that none of them is the culprit. If that doesn't fix the problem look for some hatchet job on the wiring at the rear of the truck. Bad trailer wiring is usually responsible for this.
Vince
Old 07-20-2005, 07:41 AM
EasyDuzsIt102,
I had this problem on a chevy of mine way back when. It turned out to be a bare wire in the trunk from carring heavy items in there and one of them pinched the wire causing the intermitant short of the lighting circuit.
Good Luck
Scholman
Old 07-20-2005, 09:53 AM
what 302 sain...those acrs were notorious for wiring problems in the rear seat/ trunk area. Check the trunk area first
Old 07-20-2005, 10:09 AM
They call me the Malibu
Had a similar issue in my 78 Malibu. Turned out to be the wire powering the internal lights was grounding out, on a connector that runs to the engine bay.
So check the ENTIRE Power wire.
Basic fuse block rewiring y5e06 Electrical 2 06-02-2005 06:46 PM
fuse block problems mxpmxp Introduce Yourself 1 12-29-2004 08:16 AM
Engine Problems, Oil related or coincidence only? Francis Engine 1 05-12-2004 06:56 AM
More Problems w/Electric Fan horvath Electrical 13 04-12-2004 11:52 AM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
