fuseable links on 68 cougar?
does the red/blue wire going to thh starter solinoid have a fuseable link and if so where?thank you for any help.
links
Doc here,
Should be located on the Battery Side of the solenoid , 10 gauge secondary wire on that post...or depending on how wired, on the horn relay (Old Chevy). May also be a Maxi fuse...not sure on a Ford that old though.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
i've never seen a fusible link, on any 60s ford, connected to the starter solenoid i've ever worked on - and that would be quite a few! i know that on 64.5-68 mustangs there was only 3 fuses in the entire car: panel lights, cigarette lighter, and the dome light, i believe. everything else ran through mechanical switches, which can be a pain to diagnose at times (non-constant resistance problems are somewhat tricky to pinpoint).
thanks
thanks for the input.I got it figured out it has some sort of relay with a cable running ro it from the steering column and the cable was out of adjustment.
links
Doc here,
Not being a Ford guy..I guess I should have said...."If I were to install one...It world be on the battery side of the solenoid.." Sorry "bout that... I'm sooo used to Gm... Doc
| what is the fastest (factory) car you have ever driven? | badknuckles | Hotrodders' Lounge | 320 | 12-09-2011 01:32 AM |
| '68 Cougar with suicide doors? Any pics out there? | carnuck | Body - Exterior | 7 | 09-07-2004 10:13 AM |
| 68 Camaro 4-link but 2 links centered on axle | mdowdell | Suspension - Brakes - Steering | 0 | 06-09-2004 04:51 PM |
| Rack and pinion for 68 Cougar | EBlack36 | Suspension - Brakes - Steering | 9 | 04-03-2003 06:47 PM |
