fuses - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2005, 03:11 PM
wayneair's Avatar
slinky+esculator=infinite fun
fuses
how many amps does the power to the dist draw? is a 10 amp fuse sufficient? and a fuse for a one wire alt, 70, 80, 90 amps?
Old 11-05-2005, 03:47 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If it's a stock HEI, 10 amps will be fine , maybe a bit high...
The Stock coil draws about 6 amps..so a 7.5 SLO~BLO would be good..
If it's a "HOT" or Comp coil..It can draw up to 10 amps..
To be sure, measure the resistance across the primary side and divide that by 12 volts..It will tell you exactly how much current it will draw.
Use a slo~Blow fuse, as a coil circuit can spike and blow a fast acting fuse..slo~Blow's will hang in on spikes.
An Alternator Circuit requires a Fusible link on the big red wire. ALWAYS install the fuse link at the source of the current OUTSIDE the vehicle..Fuse links work by burning up..and can melt and set interior parts on fire, and the fumes are toxic in a closed cabin.
Doc
Old 11-05-2005, 04:43 PM
steve t's Avatar
ex biker, now hotrodder
hey doc, you know a lot of stuff, thanks for being here when we need you, steve t
Old 11-05-2005, 04:47 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Thanks Steve!
No sweat, we do what we can..
Doc
Old 11-05-2005, 05:12 PM
wayneair's Avatar
so what amperage does the cable form the battery to the alternator need to be able to handle?
Old 11-05-2005, 05:40 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
For a stock 63 amp Alternator, 10 gauge wire should work just fine.
If you have one of those super duty high output alternators, you need to find the output rating and size accordingly..
Doc
Old 11-05-2005, 05:51 PM
wayneair's Avatar
uh, yeah, i had a temporary loss of consciousness or something. i knew that. i've already got 6 gage for the 100 amp alt i have. i feel kinda dumb now.
Old 11-05-2005, 06:14 PM
docvette's Avatar
Wiki Edits: 12
Doc here..
No sweat...
I do endorphin misfires all the time...
Comes with age..
I get to learn my phone number each day...and address...
Come home with a Different Corvette from the parking lot each trip to the mall..
All part of life experience..
1995 Mustang fuses ArmyofOne Electrical 2 09-22-2004 11:52 PM
running w/ no fuses 65truck Electrical 16 04-04-2004 09:26 PM
signal and brake light fuses blow billybob_v10 Electrical 3 08-15-2003 06:14 PM
blowing fuses MIKE T Electrical 3 02-09-2003 01:53 PM
Fuses Juansupreme Electrical 5 12-17-2002 06:19 PM
