Fuses keep burning out - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2007, 07:25 PM
Last journal entry: epoxy paint
Hello all. I have a 1970 el camino with a 350 sbc. The previous owner swapped out the original engine for a later model engine. There is now an MSD Hei distributor. the only way that I know it is a later model engine is because the spark plugs are smaller than they should be for a 1970 chevy.
I am having a problem with two of the fuses in the fuse box. They are burning out. the fuses that are burning out have been the 10 amp Radio/accessory fuse, as well as the 25 amp Ign. fuse.
The battery terminal on the Hei Distributor cap is connected to the ACCESSORY terminal on a Toggle switch. The POWER terminal on the toggle switch is connected, with 14 gauge wire, to the ACC (accessory) terminal on the fuse box.
I have a feeling that as I am trying to set the timing and revving the engine, the fuse is burning out. sometimes its just one of the two fuses, and sometimes its been both.
Where is the best place to connect the battery terminal. I thought that the fuse box (with key turned only) accessory terminal would be the best. I'm assumming that this is wrong. Thanks
-Matthew
Old 08-30-2007, 08:08 PM
docvette's Avatar
Wiki Edits: 12
Doc Here,
Find the wire dedicated OFF the Ignition switch for the HEI , or Ignition power..
Back when it ran points, 15 or 20 amp fuses were OK, But not so for HEI anymore...
14 Gauge BTW , is way under size for the draw of a Modern HEI under a full load..That wire should be about 10 gauge..Toggle switch Should be rated at at least 30 amps contact rating also or it's contacts will burn open or weld shut..or just melt altogether..this is a good option for a relay.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-31-2007, 12:57 AM
Actually Doc, now that you mention it, I do have a relay that goes to my Batt. terminal on the distributor and the other end goes to the switch. I got the relay points from a prior post that you had recommended to somebody else.
I dont understand what you mean when you say Find the wire dedicated OFF the Ignition switch for the HEI , or Ignition power.
Do I have to take off the seering column to get to the ignition switch (im finding this very difficult, i cant find the right puller at any parts store or in my toolbox)
Old 08-31-2007, 04:23 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
You should be able to locate that wire at the bottom of the steering column PLUG....
It will be big, (about 10 gauge), and PINK or RED or ORANGE in color..It will go on and off with the key ONLY..This is the wire you want for your coil.
On the other...you m0ost likely have an aftermarket device on the line connected wrong...or (now) Defective, disconnect devices until the fuse holds on that branch circuit...that is the offender.
Doc
Innovations
Wood burning autos dinger Hotrodders' Lounge 1 01-04-2007 04:07 PM
burning oil davidwobken Engine 1 10-25-2005 11:24 AM
Burning in clear. BarryK Body - Exterior 13 07-22-2005 12:48 PM
keeps burning fuses worknprogress72 Electrical 1 09-25-2004 03:40 PM
signal and brake light fuses blow billybob_v10 Electrical 3 08-15-2003 06:14 PM
