Rule of thumb is anything that takes lots of amps....use a relay. Things like electric fans, electric fuel pumps use relays. The other things you mentioned you can get away with fusible links.
They provide two different functions. Relays are a way of controlling a high current circuit without having to run all the current through a switch on your dash. A fuseable link is a circuit protection device like a fuse. Even with a relay, you still need circuit protection ie a fuse or circuit breaker.
Fuseable links are fine until they "blow" then they are a pain to replace. Fuses and or circuit breakers are a better way to protect a circuit. Self-resetting circuit breakers are a nice alternative when you have the space. |
As aosborn said, relays and fusible links are for two separate functions:
Main power feed from battery or distribution point, high amperage draw (like 60-100 amps) - use a fusible link Provide power to an individual accessory, low to moderate amp draw (up to about 30-40 amps), need to switch or control with a low amperage switch or sensor - use a relay For example: -- Use a main power feed from the battery (e.g. 8 gauge wire with 12 gauge fusible link) to a junction block. --From junction block terminals use smaller gauge wires (10-16 gauge, depending on amp requirement) and appropriate size fuses to connect to each relay. -- Use low amp draw switches (1-2 amp) to control each relay and activate the device. Bruce |
Power Seat = You need to use a self resetting circuit breaker (SRCB)
Power trunk release = 10 amp fuse should suffice Diving lights and 3rd brake light = If tied into existing vehicle wiring, will already have circuit protection in place. There is a SRCB integrated into your headlamp switch, and the feed to your brake lamp switch is fused. Electric Fan = Needs to be wired with a relay. GL, Tech |
Having a circuit breaker does not simply anything. From MadElectrical, "Chevy began installing Fusible Link wires in the main-power circuits with ’66 models, and of those old cars that are still in use, most of the original Fusible Link wires are still in place. If a Fusible Link burned out then it saved the car!" |
| Fusible links | Irelands child | Electrical | 8 | 07-06-2008 10:29 AM |
| Converting Fusible Links to Inlines | dsmith1279 | Electrical | 13 | 09-03-2006 02:56 AM |
| Painless Harness and Fusible links | cucumber1949 | Electrical | 6 | 10-11-2005 06:12 PM |
| Where to find fusible links | 49dream | Electrical | 6 | 02-03-2005 06:22 PM |
