fusor seam sealer - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2006, 02:08 PM
fusor seam sealer
bought fusor seam sealer and gun. question can i use part of the tubes ? how do i seal up the remainder? do you clean the spout that came with it? i sound dumb on this but i was mostly mechanical this my first shot at body work and paint . i already picked a lot from you. thanks.
Old 06-07-2006, 03:59 PM
BarryK's Avatar
Sure you can, a cap should have come with it and if it did take tip off and screw cap on, if not leave the hardened tip on the cart and store cartage tip facing down so you don't plug the two orifices in the cartage.
You cannot clean the tips and must buy new ones for each use.
Old 06-07-2006, 04:40 PM
Actually it is possible to clean the tips barry. I had a really cheap boss years ago that made us clean the mixing tips after using adhesive befpre it hardened in the tip. We would blow air through it into a rag and then dump a little lacquer thinner in the tip and blow with air again. I personally would rather pay the buck for a new tip then mess around trying to clean one out and have a chance that the mix could be off cause off a little old hardened adhesive in it and messing around cleaning it. Then again, he use to go around and pick shop towels off the floor that weren't used a lot and tell us to reuse them. What is it, about $1.50 for a roll to buy? Some people, He had to have a couple screws loose. You can imagine what the pay was like there, Geez. I've worked for a few doozys.
Old 06-07-2006, 08:49 PM
I had a boss that would resharpen single edge razor blades! Now this was in a collision shop! I don't like to waste, I don't like garbage, and I don't like to buy when I don't need to but sharpening razor blades and cleaning mixing tips sure isn't time well spent when there's money to be made.
Old 06-08-2006, 12:11 PM
cruzinTLT's Avatar
Lovin' The Cruzin'
re: fusor seam sealer
That's kinda like that commercial where the couple is washing out their old paper towels and hanging them up to dry
Waste is bad, but disposable means "throw away!"
Old 06-08-2006, 03:08 PM
BarryK's Avatar
I have been in shops over the years that had the cleaning down pat.
One shop owner had made an add on to his gun cleaner for the tips and he said the bodyman could clean a tip in about 15 minutes.
WOW! How may ping dings could he wipe in that 15 minutes.
Truly penny wise and dollar stupid.
Has anyone ever had sealer turn into wrinkle paint before? JoeySummers84 Body - Exterior 5 02-06-2006 06:31 PM
Seam sealer staying tacky :( Ripped Body - Exterior 4 10-16-2005 12:36 AM
White Sealer nova69 Body - Exterior 5 08-26-2005 01:51 PM
New heads...thread sealer or not? wickster Engine 3 03-06-2005 09:29 PM
Gasket sealer atlantis Engine 4 02-27-2005 08:41 PM
