Hey, Ok... this may sound like a really dumb question and im sure if I was reading this i think it would sound like a really dumb question but here it goes. Are there any ways on being able to do some sort of power brake in a fwd car. I don't have a hand brake but i was thinking maybe pressing on the parking brake and just nailing the gas. I really don't know why i want to know but im just curious i guess.
Thanks
Aaaa... not on a normal car there isnt. I know there are kits around to cut off the rear brakes on RWD cars so you can do burnouts and what not.
But for front wheel cars, the hand brake still controls the rear brakes and the brake pedal makes the front brakes contact and grip way before the rear.
The rear brakes come on first, thats what keeps you straight.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Used to valet park cars part time on the weekends for extra money when I was younger and we used to power brake FWD cars using the E. Brake. Problem is just like power braking a RWD car you still need an engine with some balls. Some are tricky. I power braked a FWD Lincoln once that was cool but because the E. Brake pedal is released automatically when the car is put in gear so I had to hold down the E. Brake pedal with my left foot and stand on the go pedal with my right foot. She smoked the piss out of the front tires while dragging the rear tires across the parking lot. It is obviously easier with a hand E. Brake cause you can release the brake by simply releasing the lever. With an E. Brake pedal you have to work the pedal with your foot and the lever by hand to release the E. Brake.
A bungee cord hooked to the driver side seat frame, when stretched to the e-brake release handle will allow you to simply release them when you let your foot off the e-brake pedal.
Now, when it comes to the disc brake rear e-brake set-ups they instruct you to pump them to set on some (if not all) systems, work them until they are properly adjusted, and find a way to TEMPORARILY disable the locking mechanism that keeps it set.
MOST IMPORTANTLY, MAKE SURE TO LEAVE THE EMERGENCY BRAKES FULLY FUNCTIONAL FOR WHEN YOU NEED THEM OR BEFORE SOMEONE ELSE DRIVES THE CAR
Especially if it's someone elses car you are borrowing to beat on.
My dad was one P-O'ed man when I played with any of his vehicles before getting my own.
Just curious, why would you want to do this anyway. My nephew races in the import drag series, (Nissan Sentra) he said he only did a burnout ONCE......did to much damage to do it again...but then again he has a mid nine second car.
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
