FWD Rebuildable Struts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2011, 06:24 PM
scrot's Avatar
My Toyota Corolla is making a lot of rattling noises from the front when I go over bumps. I've check the control arm bushings and ball joints for play. They look good, so I've narrowed down the possibilities to be the struts or inner cv joints.
Most auto parts stores list complete replacement struts as the only part available, but a few list the shock cartridge that goes inside the strut. It has the original struts.
I'd like to save a few bucks and replace just the cartridge.
How can I tell if the strut is rebuildable by just replacing the cartridge?
Are all struts rebuildable?
I believe the cartridge is screwed into the top of the strut.
Thanks.
Old 01-18-2011, 04:11 PM
scrot's Avatar
bump (like in the front end)
gm 10 bolt posi- rebuildable?? pic inside biggeazy-e Transmission - Rearend 12 08-05-2009 10:15 PM
choosing the right struts KoTT Suspension - Brakes - Steering 1 06-12-2009 06:58 PM
Rebuildable mechanical fuel pump? jvillen1 Engine 2 04-25-2009 10:03 PM
is a electric fuel pump rebuildable chevelle4542speed Engine 3 06-25-2006 11:18 AM
New 350 block vs rebuildable one. Jag Daddy Engine 1 05-01-2003 02:19 PM
