FWD V8 in rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2008, 08:55 PM
FWD V8 in rear end
I am starting a project with a complete GM V8 with a front wheel drive tranny. the design is to place this in the rear such as dune buggy or sand rail. does anyone know if I will run into any problems trying to make this street legal?
Old 09-12-2008, 09:08 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Nope dont know nothing about that ;)
I have a 1986 Pontiac Fiero. Its a standard 5 speed. It has a 350 SBC installed using a V8Archie kit.
Motor in the back
Old 09-13-2008, 04:07 PM
If your looking for a true bolt together motor and tranny you should look at the front wheel drive Cadillacs. How about a big block out of a Eldorado.
Just remove the steering rack and bolt the tie rods to the frame, just like the Fiero.
Old 09-13-2008, 08:09 PM
Jmark's Avatar
If you are going to mount it in the rear of a chassis and you just rotate it 180 degrees and mount it up, you will have 4 reverse speeds and one forward. You will need to keep the original orientation with the engine on the forward facing of the transaxle. Might make for a tough install with the engine jammed in between you and the transaxle.
Old 09-13-2008, 09:02 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Setting the entire transaxle complete with radiator toward the front of the car just like it sits now in your donor car will work and has been done many times. Make brackets on your frame to accept the tie rods so you can adjust the toe-in/toe-out on an alignment rack and deep-six the steering box.
As far as.....would it be street legal? That would be a question to be answered by the NC Department of Motor Vehicles. Also ask about emissions while you're talking to them. If you have to register it as a 2008 vehicle, it may have to comply with 2008 emissions as well.
In Phoenix, they have a special testing station with a crew of technical people on staff to answer these kinds of questions about Arizona compliance. See if you can locate the same type of facility close to you.
Old 09-14-2008, 12:26 PM
Yeah no brainer, I did this with an Olds Toronado into a Toyota Hilux pickup a bunch of years ago. Lots of fun back when gas stations had attendants and you asked them to check the oil.
Radiator went in the standard posiiton behind the front grill. Plumbed with 1-1/2 inch copper pipe between. using rubber radiator hoses to make the connections.
Vehicle was already licensed but it had to pass emissions. All the Toronado emissions stuff came with it and was functional. State of California was happy with it.
Bogie
questions about rear end mounting purch modification Riley Transmission - Rearend 7 08-09-2008 08:04 PM
5 on 5" rear end swap in my '62 GMC - 10 bolt vs 9" vs Dana 44 Chuck78 Transmission - Rearend 8 07-22-2008 10:01 PM
rear end ID horses1965 Transmission - Rearend 0 06-25-2008 09:24 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
