FYI epoxy primer in a spray can from NAPA
might be some other places to get it but there is now an epoxy primer in a spray can. (will adhere to galvanized metal too).
price: $22 per can!!! ouch. bought a gallon of epoxy primer and qt of cat for $80! i am going to paint my truck again. this time with something non-porous. going for the Ragged (also called Dazzle) Camoflauge look till the war is over. (currently is olive drab, it's in my photo album). bye bye |
Actually it is, there is at least one outfit (can't for the life of me think of the name right now but I am sure someone will) that makes a 2k rattle can paint and primer. The activator is contained in a separate cell inside the can and must be released before use then it must be used up completely since it will have a very short shelf life once activated. I don't know how well this stuff works but it is fairly expensive and I am not sure it would be worth the hassle.
Brian |
I would be very interested in any more information on this. I'm writing a wiki article on Rust, with information culled from analyzing over 400 forum threads on rust. The Epoxy primer section contains the following information, which I've seen repeated on the board many times:
HomemadeTools.net -- Thousands of Homemade Tools |
Jon, here is the link to the REAL 2K urethane clear in an aerosol. But even after calling Rubber Seal I couldn't get a link to the epoxy. If you go to this site and call them you can confirm it DOES exist. I have a can in my garage, but am yet to try it out.
Brian http://www.rubber-seal.com/prodview.asp?prodID=1930 |
Thanks MARTINSR. Just got off the phone with Jeff at Rubber Seal.
It looks like they don't yet have a link up on their site with the 2-part rattle can epoxy primer details. Jeff confirmed that the product does indeed exist. He said to shoot him an email, and he'll get back to me with product details or literature. I just sent the email, so now we're awaiting a reply, and we'll take it from there.
I would use the best epoxy money can buy as well as the most durable paint, because if you wait till your war is over before a re-paint, your truck will be rotted out! Dan |
Vince |
I just got an order of SPI black epoxy and activator. The total cost for 2 gallons mixed was about $142. Which is less than the cost of 7 cans of that stuff. Not sure how much actual paint is in those cans, but can be sure that 7 cans is no where near 2 gallons.
For someone that has no compressor and only a small area to do, it may be a viable option. Other than that, I can't imagine going that route. Aaron |
The 2-part aerosol mixing method is interesting, although likely not the "best" solution for most situations.
Rubber Seal got back to me. It looks like they don't yet have the info up on the web, but they sent me a data sheet. Attached is a pdf of their 2K Jet Dry Epoxy Primer/Sealer. I've also started a simple wiki entry: Epoxy primer. Feel free to add information, edit for clarity, or correct any errors I may have made.
That's kinda neat. Might prove pretty handy for the DIY guy. The 96 hour "pot life" is not bad either, though it does take away some of the convenience factor.
If you are needing to use spray can primer, I believe this would be the one to try! |
The time factor may be a problem for many. I know a lot of people that only make it to the garage on weekends. They would have to use it all on one weekend, or throw it out the next time they went out there. It would work good for someone that simply has a small spot they are trying to fix, and they are not set up for spraying with a gun.
Aaron |
| Self Etching or Epoxy Primer | Ron M | Body - Exterior | 14 | 11-30-2010 06:23 AM |
| epoxy or etching primer over bare metal? | pineknot | Body - Exterior | 21 | 03-16-2007 07:53 PM |
| epoxy primer for dumbies? | tinman386 | Body - Exterior | 10 | 03-13-2007 04:23 AM |
| PPG Epoxy Primer Question | Z-Money Pit | Body - Exterior | 5 | 08-15-2005 04:08 PM |
| purchaced spi epoxy primer | staircasesurfer | Body - Exterior | 6 | 05-30-2005 04:14 PM |
