Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - FYI epoxy primer in a spray can from NAPA
  #17 (permalink)
Old 09-13-2011, 10:41 PM
JLK JLK is offline
Try Spray Max 2K Epoxy Primer in a Rattlecan...
Recently purchased two cans of Spray Max 2K Epoxy Primer PN 680032 from Eastwood; sprayed bare metal trunk compartment in a mid-engine exotic because I needed a paint that wouldn't disolve from a drop of brake fluid. Spray Max 2K Epoxy Primer spray nozzle worked exceptionally well, layed down a very nice even coat which curred overnight. I will definitely be using this paint again... Was very impressed with results. As good as any professional spraygun, without the cleanup mess.
