Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - FYI-Smelly Torpedo Kerosene Heater
Old 01-01-2013, 09:09 AM
bondo's Avatar
bondo bondo is offline
Originally Posted by jcclark View Post
I finally figured out why my torpedo kerosene heater smells so much worse than
when it was new. I changed the filters, set the fuel pressure and cleaned it
out, but no difference. So I removed the spray nozzle, disassembled it and found
a real small "O" ring on the end of the brass nozzle that seals it to the plastic
housing, replaced it and "bingo" it made all the difference in the world.
Just thought some of you would like to know
Ayuh,... Those nozzles are Cheap,...
I replace mine, anytime I take the thing apart...
It's the only way to insure yer gettin' a Good spray pattern...
