g body - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2012, 07:13 PM
g body
What 8.8 will fit in my 79 malibu
Old 08-21-2012, 12:27 AM
bigdog7373's Avatar
Of course it's fast
Youre talking about the rear end i would assume. I believe just about any 10 bolt will fit your car.
Old 08-21-2012, 03:15 AM
If youre talking about the Mustang 8.8, non are a bolt in, you would need to source one from the scrapyard, and remove the ford brackets and weld on a set that matches your control arm arangement.
I believe there are a couple of aftermarket companies offering axles already modified to fit your car.
Measure the width of your rear axle(backing plate to backing plate) and go measure some mustangs, aerostars, rangers, to see which is closest
LT1 balancer difference issues, F body to B body fast68 Engine 10 08-11-2012 10:52 PM
g-body to b-body rear end swap? 95coughnut Transmission - Rearend 5 04-25-2008 02:46 AM
32 Ford body, firewall and body bolts heyjude076 Body - Exterior 5 11-20-2006 06:57 AM
3rd Gen F-body rear discs on 65 A-body 12 bolt? smallblocker2 Suspension - Brakes - Steering 7 03-22-2006 01:51 AM
g-body to a-body rear end swap? 85Sierra Transmission - Rearend 3 11-24-2005 02:34 AM
