g body abody rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2011, 02:23 AM
hello, can any body tell me if a G body rearend will bolt into an A body frame? we need a rear end that is slightly narrower to accomodate different wheels. thanks
Old 10-28-2011, 04:31 AM
poncho62's Avatar
Wiki Edits: 5
Pretty positive that they wont.....and the G body rears are quite a bit weaker generally
Ontario Rodders
Old 11-01-2011, 11:35 AM
Usually people go the other way to get the stronger A-body axle under a G-body. The ears for the suspension arms are at a different angle. You can force the arms to fit, but the suspension will bind as you drive. The G-body axle is about 4" narrower. More to the point (as noted above), with only a handful of exceptions the G-body axles are the 7.5" units that are MUCH weaker than even the lowliest A-body axle. By the time you get the custom offset wheels to make it work, you might as well get a 10-bolt A-body axle.
Old 11-03-2011, 08:13 AM
exactly what Joe said.....
g-body to b-body rear end swap? 95coughnut Transmission - Rearend 5 04-25-2008 01:46 AM
Kicking Rear Body ? Or Rear End? GIXXER07 Transmission - Rearend 3 08-03-2007 09:55 PM
3rd Gen F-body rear discs on 65 A-body 12 bolt? smallblocker2 Suspension - Brakes - Steering 7 03-22-2006 12:51 AM
g-body to a-body rear end swap? 85Sierra Transmission - Rearend 3 11-24-2005 01:34 AM
f body rear njbloodline666 Transmission - Rearend 4 07-21-2003 05:43 AM
