G Body Battery Location - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2012, 03:53 PM
Hello all ! I have a buick regal with a 350 setting it up for drag racing question I have is does anyone know how to do a trunk in battery setup? And where is the cheapest battery cables I can find? Please let me know!
Old 03-13-2012, 06:03 PM
Irelands child's Avatar
Place that battery over the right rear and in a racing association required box.
There are no cheap battery cables these days. If you can find some welding cable 2 gauge or heavier, that could be your best bet. It's very flexible and usually fairly reasonably priced vs the now very expensive automotive cables. Automotive cable can be a bear to work with. Mine is Taylor and from Summit, though I did have to buy more black ground wire as their 'kit' didn't supply enough for my trunk mounted battery arrangement.
You need to run the new cable to the same starter terminal as the original battery cable. Install a master shut off as well - it's usually required by most racing rules. You also need to run a ground cable, same gauge size directly to the engine then from there, you will need to ground the chassis, body and if was me, the gauge panel. These extra grounds, I use the braided cables.
Battery location for 32 Ford Tudor? RespectTradition General Rodding Tech 11 01-04-2012 08:10 AM
VIN location on mid-70s Chevy B-Body? hduff General Rodding Tech 1 11-12-2010 01:56 PM
Battery location BBCMudbogger Electrical 4 08-24-2007 08:28 AM
help, body mount pads & location/38 chev TheCiscoKid Body - Exterior 0 07-10-2007 04:34 PM
Battery Mount location PapaG General Rodding Tech 6 02-05-2007 08:56 PM
