G body coil springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2010, 12:30 PM
G body coil springs
Im putting a 454 in a 81 malibu. I have done this swap in the past and used front coil springs out of a diesel g body. I see that moroso makes springs for this swap although it says for drag use only. This car wont be a daily driver but will see street use, is there a particular reason i couldn't use these springs on the street? Or are they just covering themselves legally, by stating drag use only?
Old 03-18-2010, 01:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not a case of liability- the springs are tall and wound w/a smaller wire to get the front end up relatively easy yet allow it to settle back down for better aero.
In a street app, they'd pogo pretty bad and depending on the shocks, could bottom out fairly easily.
I've used 6-cylinder springs in both F- and G-bodies w/no problem. Car sat a little lower, but no issues w/alignment or bottoming, etc.
V8 springs should be plenty for a BBC w/alum. heads.
Otherwise, there are springs spec'ed for the BBC from the beginning, like Landrum, etc.
Old 03-18-2010, 01:39 PM
I have a BBC in my 79 Malibu with the orginal v8 springs. It only went about 2" lower which is fine with me. If you go over to maliburacing.com they have a spring chart for moog replacement springs and there forum is helpfull for g body stuff.
Old 03-18-2010, 05:51 PM
thanks guys ill just use stock v8 springs then
mounting a coil springs iceman36 Suspension - Brakes - Steering 0 04-18-2009 06:48 PM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
leaf springs and coil overs jhenry Suspension - Brakes - Steering 2 11-25-2004 05:45 AM
Cutting Coil springs MEAN_SBC Suspension - Brakes - Steering 3 07-20-2004 12:49 PM
Front Coil Springs Cecil Stainback Engine 0 10-10-2003 08:52 AM
