G-body door jam - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2006, 04:18 PM
Slant3's Avatar
84 Mutt
Last journal entry: Steering column
G-body door jam
Hey all,
I just wanted to ask a simple question----
What is the purpose of this piece and do I need it ???(see att.)
Thanks..
Old 07-30-2006, 04:33 PM
fatrat's Avatar
Last journal entry: Dave's SS 396
I believe that's a seat belt retracter.
Old 07-30-2006, 05:07 PM
Slant3's Avatar
84 Mutt
It seems to retract without it .
Thanks anyway.
Old 07-30-2006, 07:03 PM
That part is for comfort. When you are in the car and the door is closed you can pull some slack on the seat belt without it trying to retract. So you don't have the seat belt constantly pulling on you. When you open the door it retracts all the way.
Larry
Old 07-31-2006, 05:08 PM
rj57's Avatar
We have those on our '81 and '86 Montes.
Most have broken and the shoulder belts still operate just fine.
Old 07-31-2006, 07:59 PM
aminga's Avatar
Last journal entry: Cleaning and Powder coat
It's a part of the seat belt retraction system but not the retractor itself. When the lever is depressed (as it would be with the door closed) the seat belt will catch and won't retract, unless you pull it out and release it. Part of it's for comfort. but mostly it's so the belts will retract to the guides on the seat backs when the door is opened to aid in getting in and out of the back seat.
Old 07-31-2006, 08:11 PM
Slant3's Avatar
84 Mutt
Thanks all!!!
That sums it up .
I only ask because I just re-painted the jambs and the door, and I don't feel like re-installing it cause i'm afraid it might scratch up the door .
Old 08-01-2006, 02:21 PM
rj57's Avatar
Since you don't want to re-use them, are they both still good, and are you interested in parting with them?
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
Low buck body work procedure Ricky Rocket Body - Exterior 5 06-02-2006 07:53 AM
How to on Body Off Build? joeford Hotrodding Basics 3 05-09-2006 07:29 PM
Body off question... joeford Hotrodding Basics 1 05-07-2006 07:26 PM
Model A body dimensions Help! NZ30Roadster Body - Exterior 3 02-19-2005 06:52 PM
