g body engine mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2013, 06:45 PM
andrewakessler's Avatar
I have a g body frame that I'm looking to put a 350 on. The person who owned the truck before me (48 Chevy) placed some spacers between the clam shell mounts and the frame (pics attached).
I'm looking for a better solution than what the previous owner did.
Any suggestions for spacers / engine mounts?
ID:	74237   Click image for larger version
ID:	74238   Click image for larger version
Old 05-22-2013, 07:54 PM
Banned
as seen as g bodys came with chevy small blocks..
that could be for a few things
1) to move the engine back a few inches for clearance with body
or #2 the 350 he used has a truck oil pan and he needed to move it up and back..
or #3 he didn't want to build another driveshaft..
or #4 hackie hackie,butch butch..
edit, looking at the truck ramhorns, he move it back to clear the engine crossmember with the exhaust pipe..
so my guess is it was cheaper to make the mounts than get new exhaust man and oil pan for a car chassis
The Following User Says Thank You to gearheadslife For This Useful Post:
andrewakessler (05-24-2013)
Old 05-22-2013, 08:47 PM
I'm considering adding headers myself, so moving the engine back a bit makes sense. Should I stick with the clamshell mounts with new energy suspension bushings or is there a better design?
Old 05-23-2013, 03:12 PM
Last journal entry: Paint
I would use the stock clamshells. The holes are already in the frame. You just need to find out which holes are the ones to use. Maybe they did not use the right engine brackets for the clamshells. You can use the ramhorns with the bend on the bottom and they will fit.
The Following User Says Thank You to V8&4spd For This Useful Post:
Old 05-25-2013, 06:33 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
The spacers were used to raise the engine ,for a better look ,and much eaiser to work on ,Change plugs ,etc. with an S10 frame or a n G body clip in a AD truck ,engine sits really low in chassis looks bad hard to service, I also have a G body clip m85 Monte Carlo SS in a 53 Chevy p/u ,the small block looked really low so I changed to a big block ,it fits really good with Sanderson Cast iron headers. for the small block ,a set of shorty block huggers work great, looks like you have a great start ,Good luck with your build. this photo shows my frame mounts ,,seen to be same location as yours ,,not a good photo,
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
andrewakessler (05-29-2013)
Old 05-29-2013, 06:55 PM
Thanks for the info. I have plenty of space to raise the engine, so I think I'll keep the height while using a better spacer idea.
Old 05-29-2013, 08:30 PM
Built Not Bought
I tried to post a better picture ,but it will not print.
Old 05-30-2013, 02:02 PM
I don't know what's involved with putting a 48 Chevy truck body on a G body frame. You can use 72 Chevy truck ram horns on a SBC in a G body. They sell the truck ram horns brand new for $89.00 for both with free shipping. I tried 2 different style headers on a G body with a 4 speed and I could not get them to work.
body mounts chuck sprouse Hotrodding Basics 1 02-26-2012 12:24 PM
Body Mounts midsota Body - Exterior 6 08-16-2011 06:44 PM
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 09:52 AM
30 A body Mounts Fastsx321 Body - Exterior 7 10-26-2007 01:04 PM
Body mounts 38 special Body - Exterior 12 04-26-2003 04:04 AM
