g-body front suspension bushings questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2010, 07:13 AM
Absolute beginner
Hello guys,
I need some help with my 78 Monte Carlo front suspension.
I am rebuilding it with new bushings, shocks, ball joints etc.
Because I am in Bulgaria, and my Monte is the only one in the country, there are not any experienced machine shop/person to ask I hope to get some help from you as always, thank you!
1. Lower control arm bushings were flared. How can I do this flare? Can anyone show me the tool that does it?
2. How should I insert upper control arm bushings? Also, I got set of bushings that are a bit different, see the attached picture. Which one goes where?
If you need additional info I will be glad to provide it.
Thanks for the help,
Ivo
Old 11-25-2010, 07:26 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
im not real sure but this site may help you
www.montecarloss.com
theres a good group of guys over there
Old 11-25-2010, 07:37 PM
i'm thinking the bushings just press in on the bottom. i've changed them before & i don't remember them being flared. the ones pictures looks like their the same just different colors. they will just press in too.
Old 11-25-2010, 07:51 PM
ljfranssen's Avatar
monte front end
ya i beleave hes right they press in
Old 11-26-2010, 04:09 AM
Absolute beginner
Hi Guys,
Thanks for replies.
I have Chiltons manual, and they said on "later models" the bushings are flared, so it should be done when reinstalling them with special tool, but nothing more Actually, the bushings were flared, see the pictures. This is lower control arm front bushing, the thinner one. Rear bushing was not flared.
For the upper bushings, the only difference I see is the rounding on the black one. They came in set together, that's why I thing there is some purpose. The other set I have is the same, one black and one metal bushings. There is washer only on one side of the control arm shaft, may be this is the point See the picture.
What do you think?
Ivo
ID:	50347   Click image for larger version
ID:	50348   Click image for larger version
ID:	50349   Click image for larger version
Old 11-26-2010, 04:35 AM
Absolute beginner
sorry for double posting.
Old 11-26-2010, 09:01 AM
myself, i would just press them in & not worry about the flare (as long as their in there tight.) if your worried about it, just put four small tack welds on them cooling with water after each weld.
Old 12-04-2010, 01:09 AM
Absolute beginner
Hi guys,
Hi the nirto man,
I pressed in the new bushings. They fit tight so I did not do any flare or welding. I will see what will happen
The car is driven rarely so I hope everything will be fine
Thanks for the help
Ivo
Old 12-05-2010, 07:31 PM
I believe this Flaring occurs when you tighten the control arm bolts up.I think enough of the steel shell protudes that it distorts when the bolt is torqued.I have changed out several sets,both upper and lower.Never seen or heard of a tool to flare. Dale
1951 Ford sedan- questions about fusion_ta66 Suspension - Brakes - Steering 1 10-04-2005 05:45 PM
front suspension 38 DeSoto 38 special Suspension - Brakes - Steering 3 06-28-2005 10:36 AM
vw bug front suspension Blob Suspension - Brakes - Steering 5 11-09-2003 06:17 PM
69 Camaro front suspension rebuild 69Z Suspension - Brakes - Steering 9 10-22-2003 08:38 AM
Chevelle front suspension refresh mark2002 Suspension - Brakes - Steering 8 10-11-2003 01:02 AM
