G-body Manual Trans Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2005, 09:29 AM
madhat's Avatar
First off, what manual trans options came on stock G-bodies?
I have an 86 Grand National and despite the naysayers of the turbo buick community, I have chosen that I want to go through w/ a manual conversion. I found a site that showed how to use 80's F-body T5 and pedals/master cylinder to do the swap into a G-body. I am wondering if a hydralic system would be better? easier? And also, I was thinking that as long as I didn't drop the clutch and bang the gears, a T5 might handle the power, but it still might not...so I thought about the T56, which brought me to the whole hydralic clutch idea(the donor cars that I know of would be hydralic I believe).
Also, any suggestions as to what donor cars I can use, how much these parts usually go for(going to try to go for the junkyard special), where I can get a driveshaft cut(or a custom one), and where I can get a bellhousing to fit a B.O.P 3.8L
Thanks for your help
Wesley
Old 04-26-2005, 11:20 AM
daimon1054's Avatar
The T5's gonna grenade on you, Tremec makes a 5 speed that will take the power. I did not think there were any G's with a man trans but I am sure I am wrong. I would think a search would turn up a kit though as many of these cars were sold.
Old 04-26-2005, 11:41 AM
poncho62's Avatar
Wiki Edits: 5
Generally, a hydraulic clutch doesn't respond as quickly as a linkage clutch setup.
So much for the "Power Shifts"..........................
Old 04-26-2005, 02:44 PM
madhat's Avatar
arent the 4th Gen f-bodies hydraulic? I know that my rx7 is, but that doesnt really make any diff!
Are there any overdriven 4 speeds? or atleast kits to do it?
Old 04-26-2005, 10:13 PM
daimon1054's Avatar
The new vetts are all juice clutches same for mustangs the Ford GT and every Ferrari, they are as quick as anything else and never need adjusting.
Gear Vendor makes an overdrive unit for most applications. http://www.gearvendors.com/
Old 04-27-2005, 02:35 AM
dh79's Avatar
There were some g bodies made with a manual transmission. Mostly 78 and 79 malibus I think. They had a mechanical clutch linkage. People sell the linkage and pedals on ebay but they are rare so they go for pretty high prices.
Its possible to use a hydraulic setup from an F body. I'm actually planning to converty my 81 grand prix to a manual transmission. It'll be a while before I can get the money together though.
Check out these links. You may have seen them before but there is good info:
T56 into G body
Another T56 in G body
LS1 and T56 in G body
T5 into G body
dh
81 Grand Prix, 355, 700r4, 8.5" 4.10
64 Oldsmobile Jetstar, all original
Old 04-27-2005, 03:22 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
http://www.maliburacing.com/
There was a large assortment of transmissions available in the 78-83 Malibu models. I'm not sure if all below were available, but all were listed in the option codes for these years. These included the following with the option code listed:
M15 - 3 spd standard transmission
M20 - 4 spd standard transmission (Muncie)
M21 - 4 spd close ratio (Muncie)
M38 - Turbo 350 automatic transmission
MM3 - 3 spd standard transmission.
MM4 - 4 spd standard transmission.
MX1 - automatic transmission (metric or TH250?)
How to convert to manual tranny:
http://garage-scene.home.att.net/t5_install.htm
http://www.monte-list.nu/tech/fivespeed.shtml
http://www.montecarloss.com/ls1montecarloss/
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 02:48 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
Manual Transimission Conversion Tissue Transmission - Rearend 4 12-14-2004 05:18 PM
6 speed manual trans jleolion Transmission - Rearend 1 01-12-2003 11:38 PM
Model A - Automatic to Manual Trans resolution2 Transmission - Rearend 2 06-05-2002 08:42 PM
