G-Body Master Cylinder - Bore Size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2009, 07:57 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
I am currently using a master cylinder from a 83 G-body on my 54. It is the aluminum body with plastic reservoir model. The fittings are metric. I want to change this out to one of the cast iron models but do not recall the bore size for the G-body MC. Can someone identify that for me?
Also is there a cast iron MC with the metric threads out there?
Old 04-27-2009, 06:33 PM
The bore of the MC is 24mm and 36mm. It is a step-bore (aka quick take-up) MC for use with low drag calipers. The output ports should not be metric. They should be 9/16"-18 & 1/2"-20. Why do you want to swap in a heavy cast iron MC? Are you using G-body front calipers of the same year? If so and you swap masters you will need to get older non-low-drag calipers.
Old 05-01-2009, 01:39 AM
SSedan64's Avatar
82 & later are metric.
Some Info here.> http://tech.oldsgmail.com/sus_bbrake.php
Old 05-01-2009, 02:18 AM
Both napa and autozone list the master cylinder for an 85 monte as non-metric outputs. Further the 87 B-body and 87 S10 master cylinders of mine were both non-metric outputs. The bore sizes are metric, the mounting pattern is metric, but the outputs are regular old 45 SAE inverted flare fittings.
Originally Posted by NAPA
Item#: TS 101926
Price: $32.49
Core: $5.60
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Attributes:
Features & Benefits:100% OE Quality New Seals Are Installed On Every Unit. OE Performance And Reliability.
# of Line Ports:2
Brake Cylinder Bore Size:24mm
Finish:Rust-preventative Finish.
Line Thread Size:1/2-20
9/16-18
Originally Posted by AutoZone
Part Number: M1926
Weight: 3.25 lbs
Warranty: LLT
Notes: - installer warning - unit must be bench bled. If you experience any installation problems, call toll free: USA 1-866-787-5132 can 1-800-293-0760
Reservoir: No Reservoir
Bore Size: 36Mm X 24Mm
Cylinder Honing: Never Honed
New Sleeved Bore: Yes
Special Installation Notes Included: Yes
Primary - Hole Size and Location: 1/2"-20 Fender Side
Secondary - Hole Size and Location: 9/16"-18 Fender Side
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Master Cylinder Bore Size W/Hydroboost? krehmkej Suspension - Brakes - Steering 17 03-04-2007 05:06 PM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Cylinder size for 60 over bore chevy 350 BillyBanana Engine 3 07-27-2003 10:51 AM
