G-body or S-10 UCA measurements? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2008, 08:27 PM
Does anyone know what the measurements on the G-body/S-10 upper control arms are? I found some really nicely priced options for custom uppers by two different companies and I'm trying to figure out which ones to choose and if they will bolt right on.
One is from Speedway Motors - This one just says "Metric chassis" which I think is the correct application, but I don't have measurements to confirm with. They also have MOLY arms for the same style application, and they have a ton more, im sure one set they have will work.
The other one is UB Machine Once again, fairly ambiguous application to my eyes, not sure which set is the proper fitment.
Can anyone point me in the right direction or have experience with any of these? Thanks!
Old 01-11-2008, 11:27 PM
Many of the off the shelf stock car type arms are different lengths left and right. Do some searching on www.montecarloss.com because they have part #'s and I think measurements.
Old 01-12-2008, 12:24 PM
My understanding is that the G-body and S-10 have exactly the same front suspension setup, or atleast that the A-Arms are exactly the same. I guess I'm going to have to do a little digging to find out what the measurements are or which of these fit.
I need help mounting a body to frame where it does not belong! (pics inside) fiscus Body - Exterior 9 11-27-2007 05:41 PM
Sprayable Body Filler robs ss Body - Exterior 10 11-19-2007 06:56 PM
Body jig measurements and how to build it robs ss Body - Exterior 3 11-11-2007 10:36 PM
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
