g.m. LT1 '90s engine.. not the 70's - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2012, 01:22 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
question of the day.. can the intake( efi) be used on a gen 1 smallblock.. and if so what heads.. standard 87 up heads that have the new intake bolt angle.. or the truck vortec heads with the nailhead like intake bolts
looking at adding efi to a gen one small block..
thanks..
Old 01-31-2012, 01:42 PM
RippinRon's Avatar
Its completley unique to itself and the coolant ports are not the same. The LT1 and LT4 were reversed cooled.
Old 01-31-2012, 02:01 PM
stich626's Avatar
gearheadslife
back to finding a tpi then..
Old 01-31-2012, 02:07 PM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Give this a look-see: "Swapping a LT1 intake into a 1st Gen Small Block Chevy".
Old 01-31-2012, 02:14 PM
RippinRon's Avatar
That's not even worth the effort with all the other efi intakes available.
Old 01-31-2012, 02:19 PM
stich626's Avatar
gearheadslife
how so.. aftermarker intakes and rails, etc are not cheap..
tpi.. is 100.00
Old 01-31-2012, 03:38 PM
RippinRon's Avatar
I guess if you have a bridgeport and can tig aluminum well, then by all means. You have to locate and drill for the distributor, weld up the coolant passages, buy a remote t-stat housing, change the bolt pattern etc. Buy a stealth ram or single plane plain efi intake.
Old 01-31-2012, 03:44 PM
Banned
You don't need to weld coolant passages, you don't HAVE to run a dizzy, if you're going efi its a good time to go DIS, and if you're crafty you can make a remote thermostat housing.
Its not as easy as just opening a catalog and a checkbook, but it is a lot cheaper. I Also like the look of them, especially without a distributor.
Old 02-01-2012, 05:04 AM
Buick Hybrid Guy.
With all the LS1 stuff being cheap now it's not worth doing anything with TPI or LT1 anymore.
I found a 2004 LS1 engine for 175.00 on Craigs list. Repaired the broken rod due to stuck open injector at start up and freshend up the heads/2valves
and I'm rolling.
The LS1 engine is superior in every way to anything small or big block GM has ever made.
Make the switch and don't look back.
~Scott
Old 02-01-2012, 05:37 AM
Last journal entry: update
and I'm rolling.
~Scott
Where are you at? In Utah, good luck finding any truck 5.3 version for under $800. The LQ4 is up to $1400, and a real LS1 can't be had under $2k.
Then you have the problem of the oil pan. Good luck finding a used Ls1 Z28 pan for under $200. Then there's the Z28 damper, the Z28 water pump, the car intake, the matching fuel rails, the matching injectors, it gets costly fast.
Lots of threads on thirdgen.org about fitting the LT1 intake to Vortec heads, but why? Build it right, you can get just as much peak HP, with more average HP, with long-runner TPI. How about a TPI 350 with Vortec heads and a 210/220-114 500/510 cam doing 416 HP @ 5000, 396 @ 5500, and 386 at 6000, with torque of 487 @ 4000, and 430 at 2500? Or how about a TPI 383 with Extrude-Honed ZZ4 heads and a 212/218-110 487/495 cam doing 458 HP and 534 ft-lbs, with 450 ft-lbs through 5200, and 400 ft-lbs through 6000?
Average HP always beats peak HP, and Lingenfelter got famous proving it. It's all about how much torque you have at the rpm after the 1-2 upshift. That is why correctly-modified long-runner TPI always beats that ultra-short-runner crap.
Old 02-01-2012, 06:32 AM
stich626's Avatar
gearheadslife
and I'm rolling.
~Scott
this, I'm sorry is just stupid.. maybe you just don't understand what I'm trying to do..
my 71 c-10 has a running but tired 350, that will get a g.m. 96-02 vortec crate.. that is still gen ! engine.. with vortec heads...
I plan on adding efi to that.. with a MSII controller..
the truck vortecs have central efi (tbi) that's no better than a q jet..
if I'm adding efi I want it to be mpi.. the tpi, adds torque, low and mid range.. great in a truck and street car.. the lt1 intake ups the rpm breathing.. while being cheap..
your idea of just go get an ls.. is a good one.. BUT,, also has issues..
they are not cheap.. junkyards with low mile engines, know what they have.. a 4.8 or 5.3 is 1000, with everything.. want the ecu add a few hundred..
and if I'm going ls.. it be the 6.2ltr.. good luck finding those under 2500.00 from a caddy... or more from a wrecked f body or vette..
yes you can get an lsIII 6.2 listed on c/l or e bay for 800 bucks.. but one problem..
I T S H O T !!!!!!!!!!!!!!!!!!!!!!!!!!
A junkyard you have a receipt.. the c/l ad. you have nothing.. any bill of sale will mean nothing as the cops, tow your whole rig away.. oh and they don't just pull the hot engine and hand you your vehicle back,, nope, kiss it bye bye..
now add the extra's the mounts/ brackets/ front dress, oil pan, headers,
the re-tune of the ecu.. to remove the vats system (anti theft) reset the speed sensor feeds to your tire size.. etc.. add 300-600.. the adapters to run the engine behind a non ls transmission..(add a few hundred here) new fuel system
it all adds up..
ya, Icould get a 5.3 with high miles that's as tired as my 350 cheap.. 600-700.. that needs a rebuild soon..
not worth it here.. when a 2000 crate engine will bolt in..
I have yet to see a LS install that listed every little cost it took to install it..
and legit part sources.. not I got it on c/l for 400.00 the ecu re-tuned by a buddy.. we just happened to have the front dress we needed over there and all the new connectors.. etc..
hardly a cheap swap
when and if I ever do an ls swap it be in a vehicle that it make sense to do so.. like my monte SS ..
my 71 c-10 a vortec headed 350 with tpi or the lt1 intake efi.. (both cheap) and a msII (250.00) will get me 350hp and low 20's mpg..
an ls install you're talking 4k when it's all said and done..
my tpi/lt1 efi can use the ford truck fuel pump that mounts to the frame rail.. something you can't do with the ls fuel pressure needs.. go price a efi fuel tank and pump..
and remember fab time cost money..
there is a reasoning to my thinking.. K.I.S.S.
Old 02-01-2012, 06:55 AM
Now who's not being fair to the 5.3? Needing a rebuild soon? These dogs are good for at least 250,000 miles, some going well past 300,000, depending on how they're treated.
Old 02-01-2012, 07:42 AM
stich626's Avatar
gearheadslife
um, buddy.. low miles junkyard engine is a 100k on these..
I've installed enough j/y ls engines .. the low miles ones are not cheap..
so I'll play.. I get a 120k-150k ls for the going rate(here within 300miles) of 1200.00 (Everything, harness and ecu)
that has parts that you'll be replacing soon.. water pump/alt/strter/camsensor/etc.. o2 sensors..
so I saved 200-300 buying a higher miles ls.. it'll bite me in the rear in parts that will fail and down time..
my post was fair and real world.. none of the items listed above are hard to replace.. but .it adds to the cost.. and have you priced a new truck alt..
I take these things into account..
they re great engines, that taken care of will go a long while.. but they still have parts that wear out.. and tho easy to replace are far from cheap..
I've done my homework on this.. and installed over 30 junkyard ls engines..
Ford 70's 302 cam allclassicsbefore70 Engine 7 07-21-2011 06:59 PM
Help with CRS - Trying to Remember the '70's sparkydog General Rodding Tech 4 04-07-2010 08:02 PM
70's 454 or 80's 454???????? inquiring_mind2 Engine 2 11-26-2007 08:25 AM
Novice,..70's Engine turns over, won't start? dhomsey Electrical 15 08-04-2006 08:18 AM
Mid 70's 400 ci. Junk or not??? 70bird Engine 26 12-18-2005 10:37 AM
