g10 4L60E issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2009, 04:47 PM
g10 4L60E issues
My G10 has about 160k. Going down the freeway I clicked on the AC and immediately the transmission kicked down gears. Not sure exactly. After I parked and came back I tried to drive and I only have reverse and 1st gear now. I'm thinking it's an electrical issue, but when I comes to transmissions have little knowledge. There's no burning smell, or smoke. Just refuses to shift. Any ideas from the pro's?
Old 09-20-2009, 05:53 PM
Crosley's Avatar
Wiki Edits: 1659
Check the fuses
Does the Speed-O still function?
Old 09-20-2009, 07:37 PM
no dice, checked those unless there's an inline coming from the tranny. We replaced the clutch on my buddies wrx and his didn't have one.. Yeah, the speedy tracker still operates.
4L60E non-interchange issues fast68 Transmission - Rearend 10 05-28-2009 06:44 PM
95 K15 4L60e issues indianamudslinger Transmission - Rearend 3 02-05-2009 06:24 PM
4l60E issues k-star Transmission - Rearend 25 06-03-2008 07:37 PM
4l60e issues Screemincheetawheely Transmission - Rearend 1 03-06-2007 08:49 PM
4L60E issues - advice- maybe Crossley? Tim240Z Transmission - Rearend 0 11-19-2005 09:29 PM
