G3 farecla vs 3M polishing compound - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2009, 10:29 PM
Hi All,
I've finished spraying the hood, and coming to the finishing stages.
I'm looking to colour sand the top coat flat as possible and with your help polish it to a swirl free finish.
In the past I've used G3 and G10 compound after colour sanding. It worked okay. But the only down side is it still leaves swirls in the paint, and sometimes dries hard, which can be annoying to buff off.
How good is the 3M compound polishing system?
Does it remove swirls easily?
Old 08-18-2009, 07:31 PM
Old Fool's Avatar
The new 3M system and pads works excellent for me, far better than Norton's "Ice" system, but I do not know about how it compares to others.
Old 08-19-2009, 03:03 AM
Does the 3M product remove fine hair line scratches?
Old 08-19-2009, 05:46 AM
If you want to remove swirls use 3M blue glaze with the blue pad.
Yes, it will remove hairline scratches.
Issues cutting / polishing new clear blacksunshine Body - Exterior 7 11-07-2006 06:05 PM
What is the best rubbing and polishing compound? makaveli200369 Body - Exterior 2 09-16-2006 04:40 PM
Confused about what compound to get... jgrant Body - Exterior 1 01-09-2006 05:16 AM
Ok to use polishing compound on metallic paint? tcruise Body - Exterior 3 11-14-2005 02:30 PM
