gadget man groove for the throttle body?? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-08-2012, 06:52 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
he might get results on the first few pulls, but after 300-400 miles the computer will tune it out or go into limp home mode if its out of range to correct.
  #17 (permalink)
Old 02-08-2012, 11:56 PM
Race The Truck
Last journal entry: Son's Truck
Yeah that had been reported on some of the newer cars. Seems it has value on carbs and tbi motors mostly. ANyway real feed back from other diy guys.
http://dodgeforum.com/forum/2nd-gen-...an-groove.html
http://www.saabcentral.com/forums/ar.../t-204454.html
  #18 (permalink)
Old 02-09-2012, 12:13 AM
Race The Truck
Originally Posted by oldbogie
This seems to confuse throttle bodies of port and direct injection with throttle body injection and shows a few carburetors to boot.
Since the injection is electronically managed the modifications done would be automatically compensated for by the computer. The air leak would speed up the engine idle and lean out the mixture. The computer would be informed of the idle increase against the other conditions its mapped to and would command the Idle Air Control (IAC) to cut back back the throttle plate bypass air to slow the motor back down, you wouldn't even know this happened unless the change was so extreme that the IAC couldn't get control, in which case you get a code light illumination.
For leaning the mixture, if this actually occured the O2 sensors would read the lean out in response to this the computer would command the injectors "on" time to correct the mixture. Again unless the change was more radical than the system can respond to, if that were to happen you'd get the engine trouble light and a code.
The discussion about air flow past the throttle body having an effect on mixture homogenization is the same argument that was given for these type modifications and gadgets sold for carburetors. Port or direct EFI works completely different from a carburetor or Throttle Body Injection. The only thing going past the throttle body of central port, tuned port or direct cylinder injection is air. The fuel isn't added till just ahead of the intake valve on central and tuned systems, there is no manifold mixing nor is there any way of having manifold mixing. For direct cylinder injection, the fuel is added directly into the cylinder. For these the intake system from throttle body all the way through the intake valve carries nothing but air. For all these injection schemes including the CPI and TPI, fuel mixing occurs inside the cylinder.
One can argue that Throttle Body Injection suffers some of the same mixing problems with air that carburetors have. But engines using TBI since it came into widespread use in the mid 1980's all feature some sort of spin gadget somewhere along the intake tract, or in the combustion chamber adjacent to the intake valve. For Chevy it was the Swirl Port head that has a ramp just ahead of the intake valve. Ford put a similarly functioning vortex generator within the combustion chamber which causes the incoming wet flow to tumble and homogenize the fuel and air. Along with those gadgets a lot more attention was and is paid to combustion chamber design to increase burn speeds, improve burn completeness, and reduce emissions. The CPI and TPI motors pushed the head combustion chamber technology even further finding that the gadgets can be removed when the induction is only air and that the chambers can be shaped to accomplish the necessary tasks. Here you get the GM Vortec and Fastburn heads, the Ford GT40, and MoPar's Magnum to name a few.
Starting in the mid 1980s is what I call the second generation of emissions engines, you see designs that in many ways are more similar to the Muscle Car era engines than are the first generation of emissions engines of the 1970's. Basically the second generation and on has moved from reducing emissions with external add-ons and functional compromises into incorporating the function into the root design. Once that happened power and mileage began to make enormous improvements while reducing emissions.
Today we're pretty much into the 3rd or 4th generation of these emission engines, they deliver power, mileage and life expectancy far beyond that of the Muscle Car era and first generation of emissions engines. When you figure that the internal combustion engines use of the heat it makes is at best 33% while it throws 66% away in exhaust and coolant heat. One can see that there is room for a lot of improvement yet to come. This will result in a cost/mileage competitive electric car being even further away in future time. These new cars and trucks have caught governments in a financial bind as mileage has improved tax revenue has fallen while highway use, thus the need for new and repair for old highways has increased faster than revenues. Those of us living in the west are going to start paying tolls over the next few years which is going to come as a rude awakening to us who are used to going anywhere at anytime for the cost of fuel. I can't say I like it; I'm just reporting and forecasting.
Bogie
Next question On the video he is useing smog testing equipment to prove before and after results only at Idle I notice which make no sense the mod only works as you open up the throttle and the car seem to be idling normal he has to being doing more that just the groove!
  #19 (permalink)
Old 02-09-2012, 01:25 AM
Race The Truck
Found this one http://www.energeticforum.com/renewa...e-mileage.html
http://www.google.com/patents?id=opT...ed=0CDcQ6AEwAA
  #20 (permalink)
Old 02-09-2012, 05:13 PM
Race The Truck
I called the guy and sense he is in my area I'm going down and take a look at his Idea as it apply to me! 1.reducing smog 2. improving mpg 3. if there is performance that would be cool also.
  #21 (permalink)
Old 02-09-2012, 09:35 PM
Race The Truck
There is a fourm on there web site I pulled this one out because it being done on a newer chevy with a tech showing picture and testing!
http://www.gadgetmangroove.com/index...794&Itemid=829
  #22 (permalink)
Old 02-09-2012, 10:01 PM
Last journal entry: Starting the build, 333ci chev, 195 cc jegs heads
wrong post oops
  #23 (permalink)
Old 02-11-2012, 12:05 AM
Race The Truck
Sense I seem to be the only one here interested in this tech. I'm going to try to document my finding if I like what I see first off! First step I spoke to the inventor and have a meeting next week. I also took a look at there offroad short course racing that was filmed on you tube. I have a couple extra tbi laying around so its not cost me anything!
  #24 (permalink)
Old 02-11-2012, 03:40 AM
Race The Truck
I found this University in Australia Panacea! That been working with all kinds of fuel saving device we all know about. This video is of them testing the product that I'm looking at! So I will add it to my research
http://www.youtube.com/watch?v=PA9CN...DDAACB0D3808B2
  #25 (permalink)
Old 02-13-2012, 08:24 PM
Race The Truck
Ok guys, I met with the inventor today and also had the good fortune to watch the mod done on a saturn. The owner a engineer from Honeywell said it work good! I and a number of people came by to take a look at this invention including a student from UTI Which also test drove the saturm before and after! Anyway I now have a moded tbi in hand And will start testing soon! Picture to follow! Thanks
  #26 (permalink)
Old 02-15-2012, 07:16 PM
Race The Truck
Here is my testing tbi on the right, As you can see its no modded unit just a stock unit with the groove. I have set up my own personal tbi to compare the two. I will be taking it apart for cleaning before installation. What you can't see is the groove depth and shape.
Name:	004 - Copy.JPG
ID:	62995   Click image for larger version
Name:	003 - Copy.JPG
ID:	62996   Click image for larger version
Name:	008 - Copy.JPG
ID:	62997   Click image for larger version
Name:	009 - Copy.JPG
  #27 (permalink)
Old 02-16-2012, 06:44 PM
Race The Truck
Finished cleaning the tbi With soap and hot water to keep from damaging the seals on the throttle shaft.
ID:	63025   Click image for larger version
  #28 (permalink)
Old 02-17-2012, 08:14 PM
Race The Truck
Last this I do is check warping of the base. If I find low spots I block the base on my flat machined surface. Here you can see the before and after.
ID:	63043   Click image for larger version
ID:	63044   Click image for larger version
  #29 (permalink)
Old 02-20-2012, 12:43 AM
Race The Truck
After reviewing the Idle air pathway mod. I came up with my own bolt in version that fits both TBI casting.
ID:	63134   Click image for larger version
ID:	63135   Click image for larger version
  #30 (permalink)
Old 02-20-2012, 10:14 AM
1971BB427's Avatar
I can't comprehend how a modification that affects the throttle plate just at idle or slightly open would have any significant affect on mileage beyond idling or just off idle. This groove thing can't have any affect on mileage at even steady 35 mph speeds, let alone freeway speeds.
Additionally the cleaning of the throttle body alone could easily make the engine run better, and feel better, so the more gummed up or older the car is, the more likely it will run better with even a simple good cleaning, regardless of whether a groove was cut or not.
I think it's a lot of smoke and mirrors and wont make any difference unless all your car does is idle.
89 GM throttle body low vaccum on front ports of Throttle body martee373 Engine 9 02-04-2012 10:51 AM
car wash gadget 2 Bobs36ford Hotrodders' Lounge 6 10-30-2011 08:17 PM
check out this new gadget!!!! mrcleanr6 Body - Exterior 10 11-29-2005 03:48 PM
Jeep 2.5L throttle body to 4L throttle body. Parisienne66 Engine 2 07-10-2005 08:35 PM
bad throttle body? Skylark_77_455 Engine 2 12-23-2002 06:10 AM
