galaxie door panel swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2012, 12:10 PM
I have a 66 galaxie 500 conv, Im having trouble finding aftermarket door panels those of a 67 look very simular does anyone know if they will work on a 66 . note this is not an Xl package. considering dearbourn classics as my vendor
Old 02-28-2012, 02:25 PM
DanTwoLakes's Avatar
Wiki Edits: 22
'65 through '68 Galaxies are considered third generation, but the '68 model had slightly different sheet metal. The door panels may have slight differences between years, but '65-'67 model year door panels will interchange with one another. XL package doesn't mean anything as far as the size of the door panels. Be aware that you'll need the metal top pieces from the original door panels, and have to attach the new door panel to the old metal pieces. Here's a thread that tells how to do it: CLICK HERE
I have installed Dearborn Classic products before, one time I had good luck with them, and another time I had to trim excess fabric out of a seat cover to make it fit. I'm sure you won't have any problems with door panels. Mac's Antique Auto Parts is another supplier.
Old 02-29-2012, 06:31 AM
Thanks for your reply Dan, I figured they might work. The difference in the XL panel is just cosmetic but requires trim inserts wich i do not have since my Gal is but a 500. Again thanks for the info it will greatly help.
Where is the fuse panel on 1961 Galaxie MountainMan423 Electrical 3 12-20-2011 02:04 PM
installing color panel in door panel studebaker2 Interior 1 12-30-2009 07:45 AM
the door panel Question to end all door panel Questions Hogwild Interior 1 02-05-2008 02:24 PM
68 galaxie convertible--door panels?? djboen Interior 2 09-05-2006 10:20 PM
78 monte door panel swap tyson Interior 0 02-14-2004 09:44 PM
