Galv coating? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2005, 11:55 AM
Gearhead forever's Avatar
Galv coating?
Did GM use galvanized steel in the late '80's? It appears that my '87 P/U has a zinc based coating under the primer. As I am stripping it back to bare steel, does this need to come off too? Will it need to be acid washed or etched before priming/filling? (I'm planning on using SPI's epoxy primer)
Old 07-16-2005, 02:15 PM
302 Z28's Avatar
Don't know if it was galvanize, but I do know GM had paint adhesion problems in the late eighties. I would remove it down to clean bare metal then use a two part epoxy primer on it.
Vince
Powder coating Engine Chadwick Engine 4 11-26-2005 08:31 PM
Jethot Coating Manifolds RickB1B Engine 2 06-14-2005 08:21 AM
Header Clearance Issue/Question About Damaging Ceramic Coating. Ghetto Jet Engine 9 10-09-2004 12:45 PM
Exhaust manifold coating terry65elcamino Engine 2 01-08-2004 07:52 AM
Bolt coating? 77cad Body - Exterior 2 03-24-2003 12:00 AM
