Galvanic corrosion using aluminum rivets on steel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2005, 01:20 PM
Will aluminum rivets corrode when used on steel? What do you have to watch out for to avoid galvanic corrosion?
Old 08-21-2005, 05:50 PM
Aluminum rivets will corrode steel in time, how fast depends on moisture. I would not use them on steel body panels although a lot of people do. Why do you want to use aluminum? Most of the time the answer to that one is "because they won't rust" but the surrounding metal has to be protected anyway so corrosion is not a problem with steel but with aluminum it will be since you will eventually get corrosion no matter how well protected. Use steel.
gluing aluminum to painted steel? ye12 Body - Exterior 2 01-28-2010 02:33 PM
galvanic corrosion, aluminum on steel? rlackey Body - Exterior 22 05-20-2005 07:57 PM
steel -vs- aluminum flywheel fat50 Engine 12 01-04-2005 03:16 PM
Bonding Custom Aluminum Panels To Steel bmech211 Body - Exterior 2 12-16-2003 08:49 PM
aluminum to steel ghastly53buick Body - Exterior 6 10-13-2003 06:28 PM
