Gang Block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2004, 01:17 AM
nightrain_rod's Avatar
Blue Oval Finatic
Gang Block?
I am wanting to put a CB radio and an amp for my CD Player in my 1992 Ford Ranger.I was talking to some guys about it and they told me that I needed a gang block,which supposidly connects to the posts on the battery and gives you some number of "outlets" for your accessories.Did I comprehend this correctly?I want to do this without splicing into my truck's wiring harness,etc.I found a gang block from Stinger here.Is that what I need?Can someone explain to me exactly how it works?
Thanks for any insight.
Nightrain
Old 05-09-2004, 10:18 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Go to a local stereo installation shop and buy a distribution block
You can usually get one that is fused for about $10.
Later,
WEIMER
Old 05-09-2004, 01:25 PM
Blue Oval Finatic
Thanks Weimer.
So something like this is what I need?Do I run one lead and one ground from the battery to this box,or will I have to run one of each for every outlet I use?
Nightrain
