Garage Door Alignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2006, 12:01 PM
daveh's Avatar
Hi guys,
I have a two car garage and it isn't square when shut. One side stick's up about 1 inch when shut. I put some insulation inside the rubber seal at the bottom but that is only temporary. I would like to fix it the right way. I have a 3/4 hp craftsman automatic opener.
How do I adjust the door so it opens and shuts square. Thanks
Dave
Old 10-18-2006, 01:31 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
All you can do is check the door panels for being level
It is possible that your drive is not level.
This is the situation I have at my house----but not a full inch.
Bryan
Old 10-18-2006, 02:00 PM
66Caprice's Avatar
Move It On Over!
On my Craftsman 1/2 hp, it looks like the rails can be remounted or maybe even adjusted a little. Looks like it might be a two person job too.
Old 10-18-2006, 02:02 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Bryan is right, the floor could be out of level. One side may drag on the frame preventing it from seating properly. If it uses seperate springs mounted at the horizontal rail, one side could be a heavier duty spring. If the tracks are not plumb it could cause problems also.
Old 10-18-2006, 03:43 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
garage door alignment
All the suggestions posted are useful. You need a starting point, Is the door panel level? Check the floor. Is it level? This IMO will start you in a logical diagnosis on what is wrong.
Should the door not be level. Why? Spring tension, rail alignment, binding, or something else not mentioned.
Should the floor not be level.. They make a floor leveler mixture for concrete, can you cut a tapered shim, cut the door panel (if it is wood) , add a aluminum channel under the door.
Hope I gave you some useful ideas ...russ
Old 10-18-2006, 03:45 PM
daveh's Avatar
Thanks for all the useful suggestions guys. I will begin with those and report back later. Thanks
Dave
Old 01-02-2007, 10:04 PM
Garage Door
go to a good garage door installer- they sell metal chanells that go on the
bottom of garage doors which should be able to cover the gap if none of
the other suggestions work.
Need help deciding on garage heater Xenocide Garage - Tools 20 01-05-2008 10:54 AM
Maiting calls of the garage Halloweenking Hotrodders' Lounge 22 09-19-2006 10:18 PM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 09:49 PM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 07:46 PM
