Garage Door Insulation - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2006, 08:11 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
I'm looking for leads on nice garage door insulation.
I have 3 wood rollup doors that someone has scabbed 1/2" rigid foam onto the panels. This stuff has to go!
I don't want a rigid foam that breaks and gets all over the place.
Recommendations?
Old 11-17-2006, 09:03 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Actually I might wish to try some ductboard..that is a semi-rigid fiberglass that is used to make heating ducts..Or you may try the roll fiberglass tha tis used by the guys who do the metal buildings..that has a plastic over it to protect it..
Sam
Old 11-17-2006, 11:09 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
If you go to a commercial insulation firm they will have a lot of different products that you can use. Some of them are metal clad and can not easily be damaged. None of these products will be inexpensive though. You could replace the doors with insulated fiberglass ones. You all ready have the tracks and you could do it yourself. Are you constantly opening all the doors in the winter? If not you could build some interior framework and insulate that. If you build it in pieces you could take it down when you don't need it or if you have to open the door every once in awhile. I know that my main problem with insulating mine will be air infiltration from the wind and I will have to stop that before I spend any money on insulation. Right now I would say that my door leaks as much as having a two square foot hole in the wall. What is your like?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 11-18-2006, 07:28 AM
cboy's Avatar
Last journal entry: Finished
Never done this so just thinking out loud...what about the foil coated bubble wrap used for heating ducts etc? I don't trust the R values they claim for this stuff but I used it to insulate the floorboards of my roadster and it seemed to work well there. It would be easy to cut and mount you could even cross over the seams between the door panels to prevent a bit of infiltration.
Always learning...and sharing what I've learned.
Old 11-18-2006, 04:02 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
How about you cover the insulation with paneling?...russ
Old 11-18-2006, 04:16 PM
home brew's Avatar
cboy - I like your idea to stop infiltration. That type of insulation would flex as you raise and lower the door yet leave no gaps when closed.
Old 11-18-2006, 04:57 PM
Wiki Edits: 3
Now that I think about it the air infiltration deal is the biggy in heat loss so if one can get a good seal around the door and through the hinges that woudl help a whole lot..
Sam
Old 11-18-2006, 05:28 PM
risaacp's Avatar
More Horsepower Than Brains
Last journal entry: Check it out
I used 2x4 fiberglass ceiling tiles, on a steel door. They are flexible enough that you could probably lay them over the hinges.
Old 11-18-2006, 07:57 PM
dinger's Avatar
My neighbor used this stuff, it works well. Not too awfully expensive either. Dan
Need help deciding on garage heater Xenocide Garage - Tools 20 01-05-2008 09:54 AM
Maiting calls of the garage Halloweenking Hotrodders' Lounge 22 09-19-2006 09:18 PM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 08:49 PM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 06:46 PM
Some more ideas for the garage Kevin45 Garage - Tools 7 01-28-2004 11:36 AM
