Garage Door Open At The Top - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-27-2011, 08:30 PM
daveh's Avatar
figured it out the top of the door is bent in the center. I figured it out by putting a long straight edge on it. Maybe I can screw a long piece of angle iron on the top? I would need about an 8' piece.
  #17 (permalink)
Old 02-27-2011, 09:15 PM
Do you have a garage door opener yanking on it there?
There should be some reinforcement at that point already?
  #18 (permalink)
Old 02-28-2011, 12:32 AM
sqzbox's Avatar
My pipes are my music
Probably not. I have the same door and there's no reinforcement only a bracket that attaches to the center vertical rib for the door opener. The door if it doesn't now, might have had a door opener on it and it get's a lot of stress at that spot from constant use. I had to do what he mentioned with the angle iron but I used a 3' piece of aluminum angle and sheet metal screws across the top of the door on mine after the top started to crack. I also put a block of wood cut to fit in behind the bracket.
Need pic just ask. sqzbox
removing the door open stop dar130 Body - Exterior 1 05-23-2008 02:19 PM
The door wont open!! hot_rod_kid Body - Exterior 2 02-27-2008 05:20 PM
Installing Door Hold-Open Springs horvath Interior 5 12-09-2006 08:05 PM
Door closed and locked: I can't get the door open FlipperFish Interior 12 03-21-2005 06:33 PM
67 mustang door wont open Grey80Ghost Body - Exterior 8 08-03-2003 12:00 PM
