Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - garage door openers and/or springs..
Old 04-04-2013, 07:42 AM
delawarebill's Avatar
delawarebill delawarebill is offline
opener
20 yrs old.. trash it.. u can use heavier springs just so long as u balance the door with no opener attached. the cables are good, if u break a spring when its closed it can be very destructive if it comes apart. screw or chain really don't matter its really the HP of the opener.. u most likely need a 1hp or larger if a double door. but the main thing is spring set-up..
