garage floor cleaner? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2007, 02:34 PM
runn141's Avatar
does anyone know what would be best to remove the paint overspray from a garage floor? ive tried muratic acid, and no good.
Old 10-08-2007, 03:59 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
What kind of paint? And most likely it will have to wear off if you don't want to use something like thinner. Base will come off rather easily. Clear will not. The other option is to rent a floor sander/polisher for concrete and go at it that way. Then afterwards give it a good coat of epoxy floor paint.
Kevin
Old 12-22-2007, 10:39 PM
taking paint off concrete
I used one of those rental random orbit floor sanders from Menards. It was one designed for wood floors. I had to throw regular sand down on the floor while sanding to keep the sandpaper from gumming up. It evin took off some fiberglass resin that was stuck on the floor. Make sure you clean it well before returning it.
Only caution, if you are thinking of sealing your floor with epoxy test a spot that you sanded the paint off. I had spots that it still wouldn't stick to after sanding "clean."
Need help deciding on garage heater Xenocide Garage - Tools 20 01-05-2008 09:54 AM
Maiting calls of the garage Halloweenking Hotrodders' Lounge 22 09-19-2006 09:18 PM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 08:49 PM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 06:46 PM
cover it portable garage helrazr3 Garage - Tools 9 12-12-2004 12:50 PM
