I installed a used f/a natural gas furnace I purchased from A&M heating . I added a small furnace room (4'x4') on the exterior of the garage.
(if you do not have NG, then convert the burner to LP and set up a 100 gallon tank.) It is installed as a 100% loss system, there is no cold air return from the heated area. I did it this way so I could keep positive pressure in the room. I exhaust the air through a filtered man door opening. I have considered putting a return duct between the furnace room and the garage for just heating in cold weather. I would put a sealed door on this opening so I could close it for painting. $100 for the furnace A friend in the industry supplied the duct work. $200 for the furnace room materials. ![]() ![]() ![]() I hope this might give someone an idea how to heat their garage/shop/spray booth cheaply. (well as cheap as energy costs these days )
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
I should have mentioned I installed this setup for painting.
The rest of the time the garage is heated by a 40k btu NG unit heater with thermostat set at 45f unless I am working out there. The unit heater can be seen in the photo with the duct work, it is to the right side of the duct work. |
Garage heating
I borrowed a 13'000 btu oil fired/hot air furnace from a building that was being torn down
.That was 12yrs ago .Garage stays nice and warm.I put iol in the tank when I fill my house.Nicest thing is when I want to work on a project I just turn up the thermostat to 60degree's and with in 10min I in a tee shirt.My garage is 24'x30' with 10' ceilings.6" walls insulated and sheeted.So it also depends how good you insulation is.Thats what I have to offer. Stay warm,stefanP |
| Recent Garage - Tools posts with photos |
| Heater for Garage | 18-FEVR | Garage - Tools | 60 | 04-14-2009 07:49 AM |
| Need help deciding on garage heater | Xenocide | Garage - Tools | 20 | 01-05-2008 09:54 AM |
| Garage Heater Electrical Question | joeford | Garage - Tools | 18 | 12-30-2007 08:58 AM |
| Which Portable Heater Is Best For My Garage? | JimKramer | Garage - Tools | 12 | 11-22-2007 07:35 AM |
| painting in garage... water heater concerns? | Eddie N | Garage - Tools | 18 | 03-09-2003 08:06 AM |
