okay, first off TONS of great info on here. i could read through all these threads for days and not get bored.
you guys motivated me to build my own paint booth. it will be for only painting motorcycle plastics so luckily it doesn't have to be as big as the booths for cars. i would like it to be a long lasting fixture, so no need to be able to break it down. right now i am looking at making it 8'x11' and probably about 8ft high.
i am running into a couple problems. i plan on using the 8mm plastic sheeting from lowe's for the walls.
should i use wood or pvc for the frame?
if i use pvc how do i go about attaching the plastic to the frame and making it air tight?
what should i use where the plastic sheeting overlaps and i need to seal two sheets together?
how are you guys making doors on your homemade booths? keep in mind i would like it to be airtight.
thanks a ton guys.
Luke
