Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - garage paint booth help please
Old 04-23-2004, 07:01 AM
Dragon J's Avatar
Dragon J Dragon J is offline
Last journal entry: Harley/Fire
Hey Luke- saw no one answered you yet so I'll see if I can help- I have my own booth now, but when I first set up a small plastic sheet one I used wood 'stringers' for framing and stapled in to the top- sealed all the sheets with plastic sealing tape on one of those roller dispensers- made it simple to just stick and rip! For the 'door' I just overlapped two sheets, then put a brick on the bottom of the first sheet- that kept it in place as I slid between them to get out. I taped a squirrel cage fan on one end at a cutout hole and a couple filters on the other end and just ran the airhose under the sheet. Worked okay as long as you didn't go in and out a lot and always had a GOOD supply of air coming in. Be careful, as you want to follow all safety precautions- respirator, good airflow, light, etc... Good luck and hope I helped!!
