i'm getting ready to paint the vette this week, a couple of things i need to note, maybe ask a few.
i mistakingly used plastic to cover the underside of my doors while i primed the surface. when dry the primer flaked off and made a mess,will this happen in a spray booth made of plastic?? or will not spraying the booth walls be enough.
as far as a door goes , a frame of wood with plastic over, fold some plastic and staple it on as weather stripping.
i've got 3m filterte furnace filters and regular ones as a backer, will this do?
also i'm using the fan off a hot air oil furnace.they work well and there real cheap used.
in a more used application(using mine once)would it be better if it was made of cheap nylon cloth or the like??
the seams will be duct taped as will the spots on the wall where i will shoot the staples in to hold the plastic..i'm plasticing the floor too and seaming it all tight to the filters and fan, like in a big pop bottle. will this work or will i still have dust in the finish??all opinions welcome.mike
