Garage Pak air compressor piping system - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2004, 11:08 PM
montea's Avatar
tryn to learn
i just seen the add on TV
http://www.garage-pak.com/
to bad they dont give the prices, must be expensive.
Old 09-06-2004, 01:18 AM
Old enough to know better
That stuff looks really slick but I'd be afraid to ask for a quote.
I've seen a similar (likely cheaper) system that uses poly pipe rather than the aluminum but still was a push toghther system. I''ve just forgotten where I saw it now.
Old 09-06-2004, 08:22 PM
302 Z28's Avatar
Outrageously expensive would be more like it. Just use cold water pipe PVC, it is rated to 450psi. Take extra special care with the glue joints.
Vince
Old 09-07-2004, 12:28 PM
montea's Avatar
tryn to learn
i just got a qoute...
$430 for basic
$705 for deluxe
now thats expensive...
OPTIONAL HOSE REEL
(25FT)-$149
(50FT)-$223
OUCH!
Old 09-07-2004, 07:00 PM
302 Z28's Avatar
No kidding, who buys this stuff
Vince
Old 10-08-2004, 12:41 PM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Crap, thats expensive alright
Old 10-10-2004, 09:22 PM
Who buys it? Did you guys miss the link to the Yuppie garage a couple of days ago? That's who.
Old 03-09-2005, 11:46 AM
Im trying to have an idea!
* Thanks search engine - you come thru again *
Has anyone installed this stuff...
Old 03-09-2005, 12:25 PM
roger1's Avatar
Vince
Vince, I see that you actually posted this reply a while back and someone bumped this thread back to the top.
Have you been keeping up-to-date with all the negatives that have posted on this board about using PVC for compressed air lines? It is considered a real no-no. Now that I am educated about it, I am considering pulling out my PVC pipe and intalling copper. I just posted on the Garage Safety thread about this subject yesterday:
http://hotrodders.com/forum/showthre...t=31945&page=3
Roger
Old 03-09-2005, 05:20 PM
S10xGN's Avatar
Gotta love a turbo!
Hmmm, mine's all CPVC lines throughout. Been that way since 1987... So what's the nix on plastic?
Old 03-09-2005, 07:26 PM
roger1's Avatar
I'll just list some of the info I have been reading.
Read what MARTINSR has to say about PVC here:
http://hotrodders.com/forums/showthr...&highlight=pvc
Here's an OSHA link:
http://www.osha.gov/dts/hib/hib_data/hib19880520.html
More good discussions:
http://forum.doityourself.com/showthread.php?t=202549
http://www.automotiveforums.com/t333988-air_lines.html
http://www.woodweb.com/knowledge_bas...ry_system.html
http://www.oldsmobility.com/air-compressor-piping.htm
http://ths.gardenweb.com/forums/load...410414545.html
http://www.fpweb.com/archive/June_99_piping.html
http://www.woodturner.org/vbforum/sh...p?t=475&page=1
Old 03-22-2005, 03:04 AM
Short version without links:
If you happen to hit it with something hard, it shatters and sends shards of plastic into your body at high velocity.
Old 03-22-2005, 11:50 AM
Last journal entry: Transmission Table
If you are that worried use Schedule 80.
Old 03-22-2005, 02:13 PM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
PVC gets pretty brittle when its cold out. Unheated garages get pretty cold too. Lets do te math:
PVC: Fast and cheap, yet dangerous and susceptable to rupture
Copper:moderate price and moderate install time-susceptable to damage, yet safer than above
Black Iron: slower to install, slightly more expensive, but CAN BE FOUND IN BUILDING SALVAGE YARDS for next to nothing ! Just about damageproof. Safe.
Hmmm. Do we follow the "do it once, do it right" method, or play russian roulette? The choice is yours. No sense arguing.
Old 04-13-2008, 07:01 AM
Just came across this old post and thought I would jump in and give my "professional" opinion. (pipe fitter by trade)
Galvanized sched 40 is a the best option, but slow to work with and requires specials tools.
Black iron pipe is also an option, but the moisture will start rusting on the id and that will head right to your end use device.
Type L copper is also a good option, more expensive, but easier to work with and requires only a turbo torch and tubing cutter.
PVC is not a suitable product, not even the green colored product, it doesn't hold up over time.
PEX tubing is not rated for air, and is not UV stable.
And finally dont use garden hose either, I have arrived at a job site to fix an "air leak" and low and behold what did I find, a blown out section of garden hose ran across the rafters linking 2 areas together, ROFLOL!
