Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Garage Piping Help
Old 10-17-2011, 03:08 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by daveh
Hey guys,
I'm thinking of getting one of the two kits and would like your opinions. I know they are both pricey. I have copper now and I don't want to use PVC, gal pipe or black pipe. Your thoughts on these two products is appreciated. If you know of another quick connect system I would be interested in that as well. I will be using 3/4" tubing. Thanks
Kit - M7500
http://www.rapidairproducts.com/maxline_masterkits.asp
http://www.garage-pak.com/garage/pro...cat=294&page=1
This is similar to PEX Tubing used in residential construction. You say you have copper now, why change? The only thing I don't like about the tubing is if you have long runs, you have to support it every couple of feet or it will "droop". I also really don't like all those connections. Just a place to start leaking IMHO.
