Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Garage Piping Help
Old 10-18-2011, 09:22 AM
Old Fool's Avatar
Old Fool Old Fool is offline
Originally Posted by daveh
I thought the Shark Bite was for water only. If it's acceptable for air then I would probably use that.
Is it ok for air?
Thanks
Dave
Shark Bite does not rate them for compressed air. I believe the concern is if the fitting does release its grip you have the rapid expansion of the compressed gas, the same as disconnecting a quick coupler on an air hose. They do not want to accept any liability is my though.
You decide, I am not saying it is safe or not.
Myself I would just take the additional minute per fitting and sweat it and be done.
Be a hell of a lot cheaper and if you have 60 fittings you will spend only another hour or so with installation time.
If you want NOW fast, do as suggested and use a hose.
