To get started you need something to measure it all with and draw up some templates. For tools you'll need an electric grinder, some bits, some 60 reglite cartridge rolls, mandrels, machinist's dye, rheostat, that's about it.
If you use harbor freight tools and some decet carbide bits, you're looking at about $125 for the tools and such, and about 20 hours in work. |
Many times, a porting job can look fabulous, yet flow like a backed up toilet. BTW, what are the casting #'s? |
Stick with an electric grinder, it takes a whale of a compressor to run an air driven die grinder. A 6 horse Craftsman ain't gonna cut it. Pay attention to cobalt327's cold water, this isn't a place where random and large cuts make it better. Get a copy of David Vizards book How to Build & Modify Chevrolet Small-Block V-8 Cylinder Heads It'll make you a lot smarter on the subject in less time than it takes to screw up a set of heads. Though as heads go the SBC's are pretty forgiving of screw ups, not ideal, but forgiving. Bogie |
There are a few articles on DYI in the Knowledge Base on this site.
http://www.hotrodders.com/kb/cylinder-head-articles
Luv the smell of NITRO in the morning. |
You know I think that is a good idea Cobalt I think I will get it flowed the last thing I want to do is put a ton a time into this only to find that the things does not flow much at all. What Vortehc castings are the good ones? I will start looking for them. As far as the numbers go we talked about this a while back on another thread and we were not able to figure out what they were? What other casting's will work good that I might find while hunting the yard or Flea Bay??
Thanks Guy's |
Don't believe it if you hear that 906 castings have bad exhaust seats or ports, or flow poorly- it's not true. Those heads might have hardened seats w/a lip where the seat and head interface. This can be easily smoothed and the heads will then flow basically the same. A LOT of info on Vortec heads and mods to them, etc. is HERE. |
| Cylinder heads SBF | BadMonkey | Engine | 5 | 04-12-2009 12:30 PM |
| Ported Cylinder Heads? | sixty9santa | Engine | 55 | 02-06-2009 07:36 AM |
| Porting BBC heads - q's (pics) | fire_hawk108 | Engine | 3 | 04-25-2008 10:55 PM |
| twin cylinder heads | Terry411 | Engine | 4 | 09-17-2004 07:33 PM |
| Which Spark Plug Suffix on 333882 Cylinder Heads? | FBody | Engine | 3 | 09-08-2004 09:45 PM |
