We're winning the case!
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #1
Old 07-14-2005, 10:11 PM
Nightfire's Avatar
Nightfire Nightfire is offline
Young & Idealistic
Nightfire's barnstar
Wiki editor
Wiki Edits: 4
Garage smells bad, cant take it anymore
Ever since I picked up my motor and rear-end and put it in the garage it smells bad! Really bad, like old fart or something similar. I'm sure it must be the engine or rearend....but why? ANd what can I do about it? (and no they cant go outside)
Mike
Old 07-14-2005, 11:51 PM
senor_limpio's Avatar
senor_limpio senor_limpio is offline
The Dude
Mike, it's probably the rear end. Unfortunately I think you're stuck with the "stank" for now. Where were these items previously? Did anything make a home in them and possibly die? Possibly a skunk had a love affair with one of these items? Smell the oil in the engine as well. That may narrow it down to which one it might be. Burnt oil smells really bad too!
About 15 years ago I had a bottle of limited slip additive sitting on a small table just inside the garage. It somehow got knocked off and the lid came off... stinky! I didn't really mind it, but mom sure didn't like it too much.
Rock on and God bless...
Seņor
Old 07-15-2005, 06:35 AM
AhX AhX is offline
New Member
it is dmost definitely the rear end. gear oil stinks to all high hell. Your pretty much stuck with it. once that stuf gets on something forget it.
Old 07-15-2005, 07:08 AM
dinger's Avatar
dinger dinger is offline
dinger's barnstar
Wiki editor
You can get a lot of stinking out of a rearend.. Dan
Old 07-15-2005, 07:21 AM
Beenaway2long's Avatar
Beenaway2long Beenaway2long is offline
or Jeff, or Doc, or...
Mike,
YOUR READ END STINKS, BROTHER !! GO WASH IT !!
Old 07-15-2005, 09:44 AM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
Start pal'in around with a few guys that work in wrecking yards all day pullin motors and such. Within a week you'll be used to the stench of motor oil and gear grease And what BEEN said...if your rearend smells like farts...wash it!!!!!
Old 07-15-2005, 09:53 AM
Nightfire's Avatar
Young & Idealistic
Wiki editor
Wiki Edits: 4
Dangit, I knew my momma was right when she said to wash it after each use
On a more serious note, if I put the rear-end outside, will the smell go away eventually?
Mike
Old 07-15-2005, 11:13 AM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Gear oil has large amount's of sulfur(rotten eggs smell) which prevent's micro welding the gear teeth so they last longer. Enough heat can build between rubbing teeth under load the metal can melt and resolidify many times. Also the biggest cause for pitting.
To answer your rear end question, No, the oil soaks into the metal between other molecules and it'll be there for...maybe forever. If you wash it well enough to rebuild it, like acid dipping, or other caustic means, you can drasticly reduce the smell but it'll never go away completely. Making sure it has good gasket's and seals will help.
Old 07-15-2005, 12:28 PM
Nightfire's Avatar
Young & Idealistic
Wiki editor
Wiki Edits: 4
But if I take it out of the garage how can I get the smell away in the garage???
Mike
Old 07-15-2005, 12:53 PM
If it dropped oil, just use Brake Kleen on the spot. No oil, no smell.
And wipe your rear end REEEEEAAAAALLLL Good from now on!
Old 07-15-2005, 01:22 PM
PapaG PapaG is offline
Diesel Nut
You might hang some old dyer sheets (bounce) around. they may help.
Old 07-15-2005, 03:44 PM
steve t's Avatar
steve t steve t is offline
ex biker, now hotrodder
put it in a garbage bag and tie it close, if it just the center carrier
Old 07-15-2005, 09:59 PM
Nightfire's Avatar
Young & Idealistic
Wiki editor
Wiki Edits: 4
Ok thats it, I accidentally left my dads van in the garage with the windows open over night and now the van stinks like that crap if I park it outside somehwere (like go shopping) and come back it stinks, I already vented the van and drove with the windows open, and let it outside but the smells is stuck dangit this is not my week, first I delete all my parents e-mails then I stink up their garage and their van I'll just sneak out and drive my truck down to mexico now...
Mike
Old 07-16-2005, 05:11 AM
The Dude
That Febreze stuff might help with the van. Hang in there, broseph! Things gotta start lookin up from here!
Seņor
Old 07-16-2005, 06:50 AM
tm454 tm454 is offline
Tazz
the febreze is great
that stuff will keep the hornets and spideres out of the garage too!!
Tazz
Rat Rods Rule!
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Garage smells bad, cant take it anymore"
bad regulator, or bad alternator bildo95 Engine 4 01-24-2006 04:27 PM
Bad brake booster? NOlowrider Suspension - Brakes - Steering 4 05-26-2005 12:39 PM
how bad is it to ride on bad akm Suspension - Brakes - Steering 5 05-13-2003 09:28 PM
Diagnosing Bad Catalytic Converter deleteall Engine 4 04-14-2003 04:43 PM
How about a garage forum? Kevin45 Hotrodders' Lounge 3 07-28-2002 08:25 PM
