garage ventilation
need some pics and ideas for ventilateing my garage for grinding, welding, painting, really would like to keep my doors closed for noise and due to the fact it is getting cold out any help would be great. thanks Joe
it is a 21'x21' detached garage just tired of opening the door to grind or weld to get rid of the fumes thought about installing a attic fan in my window , did not know if that would work considering the cfm it has.
i have a friend that replaces heat pumps and i was at his house oneday a seen one torn apart to take off for scrap
the fan and housing unbolted from top of the unit there for it had its own frame/and grill over the blades tokeep out the birds anyway i took it home tested it out. i built a ply wood box and a door that opens and closes on the inside with a string cut the opening for the fan and mounted in place with screws. it has worked great for the last 4 years my shop is 22x20 and it pulls lots of air u could buy louvers but i got no money. no probs yet with rain blowing in someone is always updating a heat pump should be easy to find a old one cheap that will work for u. just dont do alot of painting it is not exsplosion proof Last edited by bocephus86; 10-22-2009 at 05:11 PM. |
On page 3 and 4 you will see some home made insulated vents, they are user friendly and always work good, anyway in here. http://www.1969supersport.com/paintroom.html
Rob http://www.1969supersport.com |
Here is what I used
]http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200323837_200323837?xsell=true&cm_sp= Xsells-_-Manual-_-Product%20Page [/URL]
Bought this item on EBay for about 75.00, I searched for a few weeks but there were lots of choices, hardwired inside an existing window frame and works great. Has a totally enclosed motor..just have to remember to turn on the fan BEFORE spraying so no sparks at the switch...louvers work good..I made the whole frame removeable so I can pop the window sash back in when needed. Rated at 5450 CFM... marginal for my space but works well for me. Mike B. http://www.hotrodders.com/forum/atta...id=41421&stc=1 Last edited by oldcpecdr; 10-22-2009 at 07:55 PM. Reason: wrong email attachment |
| Recent Garage - Tools posts with photos |
| Garage Workshop | ckucia | Garage - Tools | 11 | 11-20-2008 06:42 AM |
| Garage Ventilation? | djjc76 | Garage - Tools | 26 | 11-02-2006 10:02 AM |
| Maiting calls of the garage | Halloweenking | Hotrodders' Lounge | 22 | 09-19-2006 09:18 PM |
| Garage Safety | Kevin45 | Garage - Tools | 48 | 11-26-2005 08:49 PM |
| Hotrodders Knowledge Base: Garage - Tools | Jon | Garage - Tools | 0 | 11-26-2005 06:46 PM |
