garages
I have two 45 ft trailers bolted together with the sides together cut out and two I beams set up to support the cut area. This gives 16ft wide 45ft long with a roll up door. The center is left 5ft on each end, the area behind the barn doors is great for the tools. Hot air furnace works great.
You have any pics to post? Also what does a trailer like that cost. BTW welcome aboard.
Kevin |
Cost verys. I wae lucky and found 1 with the side blown out by a load shift. I paid about $1000.00 deliverd and axels removed.
Put in place by fork lift. The $1000.00 was for both. I will try to get pics sometime. |
| All times are GMT -6. The time now is 02:33 PM. |
